nismo 2 way LSD
Hi,
I have a JDM Nismo R180 2 way limited slip differential with axles. This item was removed from a 1995 Nissan S14 Silvia with SR20DE manual transmission in Japan. This differential has approximately 30,000 miles and it is in very good condition. Applications: Nissan 240z, Datsun 260, 280, and interchangeable with R160 on the Datsun 510. Non ABS Gear Ratio: 4.08 Pictures are available upon request if interested let me know located soCal |
Interesting... I thought S13, S14, & S15 had a diff pumpkin than the Z. Post some pics!
the unit came off from jdm s14 with sr20de instead sr20det and it uses r180 intead r200
let me know your email address i will send you the pictures via email. thanks |
let me know your email address i will send you the pictures via email. thanks nismopick@hotmail.com Thanks! |
Just an FYI... That differential won't fit in a "pre-1990" Z without a ton of modifying... (either fab up a custom design, or use the rear suspension from the 240sx).
Lets compare: The S13 - S15 diff is shorter & fatter than the Z's. S14 LSD: https://img.photobucket.com/albums/v413/nismopick/1.jpg 280zx - Z31T diff: http://memimage.cardomain.net/member...8_115_full.jpg http://memimage.cardomain.net/member...8_116_full.jpg |
thanks for your info,
i didn't know they use different diff housing, the seller who sold it to me told me that they would fit into the application i listed do you know if you could just swap the lsd into z diff? |
