New to Datsun
no really, power steering in an S30 is gay. it is completly uneccessary. its a manual rack so it feels like any power steering car just with MUCH better positive feedback and only becomes slightly difficult to use at a dead stop. even then, the cars weigh well under 3000lbs so totally unecessary. ive gone into steep drifts with the 260 (sorry ray only 2 times promise) and didnt even think about the manual rack cause it feels fine. all your doing by going PS is adding weight, less feedback as to what your driving on, more power train hp loss, and a worse ratio for steering. more turns.
lol... no no, thats either cause the frame at the top is goofy or you need to adjust it. look at the latch the door latches to its mounted to the car istelf on the sill. it should be held in place by two large philip screws loosen them up and it moves around, just loosen them a little bit, tap them back slowly and then re-tighten and close the door again and see where its at. it takes some playing around with to get it right.
You guys are right about that powersteering, they are really useless.
Anyway, I gave the car a really good tune up. But there is something not right, everytime the car is running it seems to be jumping the engine speed to 500rpm to 1000rpm like every several minutes. When I twist around the spark wires it seem to stay about 800r rpm, sometimes 1000rpm. When I let a day pass by I tried to start the car again, the engine speed is changing again, I have to open the hood again and wobble the wires again to make it maintian its engine speed. ANY THOUGHT?
you could start with a tune up.
shut up. lol. maybe if you havent already clean the electrical connections in the engine bay and on the ecu. also check the timing. need a timing light for that though. and its got all new gas in it right? also a vacume leak could cause similare problems
Well Guys, she running great. She stays on 900rpm. I gave her new gas, and she runs smooth. Now, She is still smoking, but not alot. there is a new law here in America, if there any visible smoke out the vehicle it can't pass smog. I don't know what to do now, the car is not a California car, so it don't have smog equipments. I want to deal with the car before the end of may.
what you can do is get a po box in a city that has no smog laws like(like where hoov100 lives) and register it there.
hoov100 lives in thousand palms just to let you know
Really? That might just work, but I am about 517 miles away from Thousand palms, but to po box it there just might work... Looks like I am going to have a road trip with my 68 Thunderbird towing the Datsun there.
ive been thinking about that stupid plan you guys all thought up, its still registered under you, so who is to say they wont base the smog off where your ddriver's license is from or your mailing address cause you have the title created under a PO box?
It is nice to see that you are getting it back together. For the smoking, I would recommend putting a can of sea foam into the fuel tank to clean out any water, to clean out the fuel lines and such. You can get here in almost any parts store. You should be be able to find it there. Keep driving it around, the ring may need to be replaced. It also may clean it self up after a few miles. Wish you the best, Rich.
For the smoking my guess would be the good ol' 280Z water temp sensor. These things have pretty much failed on every 280z that has the original sensor by now. So they'll start to make the car run alot more rich than it's supposed to be. Causing it to smoke. I noticed you said the smoke was light grey. I'm not sure what that is. It may also be alot of backed up crap in the exhaust that has sat and is making it's way out. Whenever my car sits for months at a time in a garage, when I start it up for the first time I get a bunch of smoke. Just like excess dust, moisture, etc that's accumulated in the tailpipe is making it's way out.
Thanks guys, I got it a different brand fuel cleaner and rev the **** out of the car. Still smoking, I tried to adjust the idler speed, but still smokin. The guy at autozone said, "the car might not pass smog, you should scrapped it to get the $$$ you want for it". Do you guys think that scraping my car is a good idea, just to for get it? I mean if it can't pass smog, do I just get rid of it?
I been reving the **** out of the old gas that I drained out and full it up with fresh gas, with fuel cleaner. Still no luck?
Thanks, Nick
Thanks, Nick
Let's recap:
Why is everyone telling him to do fuel treatment??? The spark plug tips will tell if fuel cleaner is needed. As for the light gray (blue??? white???) smoke... that's usually a sign of burning oil or burning coolant. You can rev it with all the fuel treatments in the world... that won't stop it from burning oil or coolant. Does it consume a lot of oil? Does the motor get hot (above middle of temp gauge)???
The color smoke is light gray
What color smoke?
blue = burning oil
white = burning coolant
black = running too rich
blue = burning oil
Let's recap:
The temp gauge haven't go up that far, I don't want to take the chance of over heating it.
I don't see if the coolant is draining in the radiator.
But the car is about 1/4 of oil
You need to narrow down the cause of the smoke. Is it blue-ish? Is it white? What does it smell like? What do your spark plug tips look like? Is the oil foamy?
Why do you think it would overheat?
Huh? You mean there's no coolant in the radiator?
1/4 full of oil? It's 3/4 empty?
