New to Datsun
Originally Posted by amanofgreatevil
I've know most people who had a datsun like mine that over heats and have to replace almost everything in the engine.
The engine has 1/4 of its old black oil.
The spark plugs are new champion, I gap them like .35 as far i remember.
Datsuns aren't prone to overheating unless they are mistreated. And... unless you drive the car 500 miles with no oil, and no coolant, simply overheating it doesn't usually require "replacing everything in the engine."
I still don't get what you mean... you changed 3/4's of the oil and left 1/4 of the old oil? It only has 1/4 oil in the motor? What do you mean?
Do not put "crapion" aka Champion spark plugs in a Japanese motor. NGK's only. So... pull out those piece of crap plugs, tell me what the tips look like, and get a set of NGK's to replace them.
Thanks
have you done an complete oil change yet? if not then do one. and nismo wouldn't tell you wrong just get the ngk's.
Thanks
just go to auto zone and ask them for ngk for your car they should know no need to get fancy/pricey just get the car running first then upgrade later. and just use what you feel necessary im going to run a high millage with slick 50 additive already in the oil but run with what nismo tells you HE IS A Z GOD!!!
call kragen,napa, and pep boys. just look around someone has to have them. where you located in cali?
Is that why my car is running so poor, and smokin alot, all because of "crapion"?
it could be they are part of your ignition and one of the three things that makes a car go: fuel,air, and fire. if one is missing or kind of off then that may be the case, but what do i know just ask one of the more experienced zdrivers.
I see, you done very well, I am sure your boss is proud
ok this has gone on for long enough, quoting each other then saying something completely irrelevant to the tread!!! but it's fun so why not
