more horsepower for my stroker please
Old Mar 6, 2008 | 10:59 PM
byrneZ's Avatar
hey, i have a 78 280z with a couple month old engine. Its bored out to 3.1L, new cam, pistons, crank, head,.....all new. I recently took it out to the track and was expecting much more then what i got. Im a little straped for cash now so i was wondering what people think i should add for the most horsepower. Ive heard many things such as rising rate fule pressure regulater, electric water pump(which would only add a few) and ovcourse NOS, but i rather not mess with that so any suggestions would be great.
Old Mar 6, 2008 | 11:16 PM
sticky280zx's Avatar
if you did that build right...go get some megasquirt and TUNE IT....ppl dont think about tunes but y dump thousands in and not spend another couple hundred on a tune so it doesnt blow....if you did it right and put some money into it you should be around 250+ rwhp and around 300+ at the crank and thats plenty in that car....till u go turbo=the right way
Old Mar 7, 2008 | 12:09 AM
I agree, but I do give him credit though. Because yes I do want to turbo my '82 280zx. But I still would like to have a n/a that is stroked. (Just not sure if it will be my '81 or '82 slicktop) Because I would have the best of both. To each his own though. Good luck with your stroker Z. And I am sure you will figure out. And get what you think, will work best for what you want.
Old Mar 7, 2008 | 10:24 AM
What is it that you were expecting? Have you dyno'd the car to get your current hp rating?
Old Mar 7, 2008 | 11:16 AM
theramz's Avatar
I have a present for you...
I heard that going to 3.1 doesn't do that much more. You have only increased the displacement by 10%. So bigger on everything else too. It's still breathing in and out of the same holes. Megasquirtnspark!
Old Mar 7, 2008 | 11:20 AM
duowing's Avatar
NisTuner
Are you still running the 78' EFI?
Old Mar 7, 2008 | 07:18 PM
byrneZ's Avatar
no i plan on installing a magasquirt
Old Mar 7, 2008 | 11:53 PM
likesaid....standalone system....and a tune + HEADWORK.....cam,angle job, valves, springs, all the rest of the stuff otherwise like he said all youve done is bore.....and maybe mill the head while youre at it if you didnt stroke it you should have upped the comp ratio with a higher set of pistons...did you do that or not?
Old Mar 8, 2008 | 12:01 AM
headwork, MS, injectors and nitrous.
Old Mar 8, 2008 | 05:13 PM
nitrous is crap. i wouldnt, thats a muscle car thing or a turbo car thing when trying to defeat turbo lag. u could always cheap out and go carb setup on the stroker. or ITB's
Old Mar 8, 2008 | 09:54 PM
byrneZ's Avatar
no this is a complete list of what i did to the engine here it is
big bore kit
p90 heads
3 angle valve job
stage 3 performance cam set
f54 l28 block
89mm flat top pistons
240z rods
ld28 maxima crank
comprtition head gasket
new bearings new gasket set
new oil pump
new water pump
new timing chin set
coated 3-2-1 header
new injectors
performance flywheel
inlarged throttle body
and a cold air intake
Old Mar 9, 2008 | 12:27 AM
We'll try this again...
Old Mar 9, 2008 | 11:33 AM
byrneZ's Avatar
well i was expecting faster then 16.7 in the 1/4. part of that might be my shifting but that around stock speed. and no i havent dyno'd
Old Mar 9, 2008 | 12:23 PM
16.7?!?!?! buwahaha! that is absolutley terrible. i think it could do better stock! thats definatly the price you pay for using stock EFI for a 2.8 low compression motor on a high compression 3.1 liter motor thats for sure. part of that is using the stock injectors im sure.
Old Mar 9, 2008 | 04:17 PM
byrneZ's Avatar
yea im looking at an aftermarket efi but im not sure which one to pick there are so many
Old Mar 9, 2008 | 08:00 PM
What is your hp goal? What is your price range? How did you get this far into your stroker motor w/o considering fuel injection upgrades????!?!?!
Old Mar 9, 2008 | 08:36 PM
260zturbo's Avatar
Stupid Hurricanes...
wow thats pretty bad, get a standalone setup but u should get a wideband and see what your afr is at.
GTH
May 20, 2011 12:19 PM
1990300zx1990
Jul 1, 2006 10:11 AM
VandiL
29
Apr 17, 2006 09:37 PM
Samz
Oct 2, 2003 11:32 AM
lonito
Jan 21, 2002 11:06 AM
