L28 into a 240z? 280zx trans?
Old Jul 24, 2004 | 07:28 PM
e_racer1999's Avatar
i believe that it will line right up... and as for the 5 speed... YES! you are gonna want the overdrive especially if you are gonna have a massive motor. another thought, you might want to get a lower (higher numerical) differential gear so that you have good acceleration with the 5 speed.... the 280zx r200 w/ 3.70 should be sufficient.
and you shouldn't have any problems installing the 5 speed in your 240. do a search on hybridz.org for the tech article on it. that way you know what you're getting into
-jason
Old Jul 25, 2004 | 01:26 PM
dr. buddha's Avatar
Z Extreme Guy
i have a simuler set up in mt 72 240z but mine is a 3.1 stroker and i have a 5 speed in mine and it all gose in with no mods. but you mite want to chaneg out the ruber bushings in it first with the urithan ones i can tell you from my expireanc that it made a funaminal difrenc and the moter mounts i used were enrgy supetion mounts also.
i also keept my 240's origenal rear end in it and i like it i have all kinds of power. i dont like the 3.7 open dif i have it on my z31 v8 convertion and i whish i had swopet it out when i had the chance.
but its all up to you.
Old Jul 26, 2004 | 11:10 AM
dr. buddha's Avatar
Z Extreme Guy
Originally Posted by SmogSUX
Where did you buy your motor mounts? Also what kinda of dif. does the 240z have on it? I will most likely buy a 1972 240 that I looked at.
sumit racing they were the chepest and they had every thing in stock.im not shure what the # is on the dif but its the stock one.
Old Jul 27, 2004 | 09:37 AM
Stricktly Z and other places sell complete urethane bushing kits for the 240Z. They are under $200 I think. That will include your suspension components too.
Old Jul 29, 2004 | 03:06 AM
dr. buddha's Avatar
Z Extreme Guy
wow not too bad. but i only paid 129.00 for mine the hole kit summit has got the hook up on this kit. but then agine there are only two sumits racing in the world and one of the retail stores is right down the street from my house, which makes it convinent for me. for i dont have to pay shiping.
Old Aug 24, 2004 | 10:21 AM
not to hijack your thread, but this is to dr. buddha: which 5 speed do you have? is it the early L278 one or is it the "turbo" one? i have the early one and the first gear is like 3.07 compared to the stock 3.5, and it's a REALLY tall gear....
Old Oct 4, 2004 | 12:06 AM
dr. buddha's Avatar
Z Extreme Guy
i tthink its a early one not shure
Old Oct 6, 2004 | 10:10 PM
evildky's Avatar
all L6 motors have the same exteranl castings, they will all interchange freely ( save for the LD28 which has higher deck height), also to my knowlege no one makes a urethane motor mount for the L6, the Master kits are all about suspension although they do include trans crossmember mounts (not the trans mount itself) they also include mustache bar mounts not the pinion mount
also if he's got he built stroker then he won't need a taller gears
also depending on the year of your 240 you may or may not have issues with the transmission mounting, the early cars 70-early71, used a shifter hole that mounted a bit further back, you might have to hack the hole open a bit, also if it's a turbo 5 speed (easily identified by the 4 bolts holding the shifter plate on) your gonna have to adjust the trans mounts as it's about an inch from lining up
Old Oct 7, 2004 | 08:28 AM
if anyone is considering using the T5 from the trubo Z, look into that further. There's a lot more to that conversion than just a transmission mount modification.
Old Oct 8, 2004 | 11:42 AM
evildky's Avatar
the drive shaft will have to be shortened as well,I'm not sure about the slip yoke being the same, most Nissan Datsuns use the same slip yoke
Old Oct 8, 2004 | 12:29 PM
The T5 is not a Nissan transmission.
You will have to use the T5 driveshaft as well to get the proper slip yoke. It will need to be shortened. The ends of the ZX turbo driveshaft neck down at either end, unlike most Nissan driveshafts that are the same diameter the entire length. Since driveline shops like to cut out the ends and not the middle, this complicates the shortening project and you may get turned away. Also, the rear flange on the driveline does not match the Nissan flange. You'll need the differential flange off the front of the R200 from a turbo Z. (automatic turbos are not compatible driveshafts)
or, have the driveline shop change out the rear U-joint. You're looking at some bucks in a custom driveshaft unless you have a really good machinist working with you. You might as well bring the driveshaft in and use the front splines from the turbo driveline and have the rest of the driveline made custom to fit your Nissan differential. The rear transmission mount must be made and set at the right height. On a car with a solid mounted differential, you want the driveline to be exactly inline with the rear of the transmission or your U-joints may go out.
Old Oct 10, 2004 | 04:43 PM
Daeron's Avatar
which turbo?
what turbo ZX had a t5 in it?
Old Nov 3, 2004 | 10:54 AM
evildky's Avatar
81-83 280Zx turbo's came with the T-5 on manual versions, I seem to recall something about 81 being automatic only on turbo cars
bigal1217
Dec 11, 2011 08:37 PM
Z_Rac3r
Apr 6, 2009 08:13 PM
slow'n'steady
52
Jun 14, 2006 02:38 PM
