i have to keep adjusting my Carb?
Old Jun 23, 2005 | 12:28 PM
dylokjai's Avatar
just pick up a 72 240z original engine with 164k ans 4spd tranny need body work tho and every time i start my car i have to adjust carburator to make it start..is it time for a new/rebuild carburator or something else?
Old Jun 23, 2005 | 12:44 PM
Fast240Z's Avatar
what do you mean by adjustment? if you have to put the choke cables on, then that's normal.
Old Jun 23, 2005 | 02:18 PM
dylokjai's Avatar
its more like spraying choke in there to make it start
Old Jun 28, 2005 | 10:53 AM
dylokjai's Avatar
since i bought this car its been hard to stay idle, can this be my carb or something else? people telling its becuase im not getting enough flow so i have to keep adjusting it but i dont know should i just rebuild my carb and see what happen? or is it time for a new motor?
Old Jun 28, 2005 | 12:09 PM
Fast240Z's Avatar
if you have to spray choke fluid in it, then that's not right. You might want to use some carb cleaner or something, you might have something gummed up in there. A carburetor rebuild is never a bad idea on an older vehicle.
Old Jun 28, 2005 | 12:33 PM
theramz's Avatar
I have a present for you...
If it runs ok after it starts and starts ok after it warms up then it's your chokes. If you have to spray it every time then it could be your carbs. You should check your timing and make sure your vacuum advance is working. When the vacuum fails, people compensate by advancing the timing. It will sem to run better but it will be harder to start. Unless you have experience with multi carb set ups you shouldn't atempt it with out a book on SUs. Do the ignition a-z first.
Old Jun 28, 2005 | 01:05 PM
dylokjai's Avatar
newb question how many barrel is the carb on a stock 72 240z
Old Jun 28, 2005 | 01:44 PM
theramz's Avatar
You have two, one barrel side draft SU type carbs on a stock 240 Z.
Old Jul 28, 2005 | 04:00 AM
ChEng's Avatar
Go to http://ztherapy.com and get their video tapes or DVD on SU carburetors.
omniserv
Apr 9, 2011 04:24 PM
Mrmoose
Nov 1, 2010 10:34 PM
3XAZOWNER
Jun 18, 2006 05:43 PM
n_2_fairladyz
Dec 17, 2004 02:18 AM
Alan240z
Aug 8, 2003 04:27 PM
