First start problem, sparked then burned wire to starter
Old Jun 12, 2009 | 07:57 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
Okay so the second I touched the positive to the battery the wire from the ignition to the starter sparked and i heard a clicking noise almost like a fuel injector firing...I didn't attempt to crank it I dont want to hurt it any more.
Old Jun 12, 2009 | 08:43 PM
Double / triple check your wiring, relays, and fuses...
Old Jun 12, 2009 | 09:46 PM
theramz's Avatar
I have a present for you...
Seems like a dead short to ground possibly in the ign switch.
Old Jun 19, 2009 | 11:23 AM
I did, and everything is perfect to this diagram (minus inhibitor relay)
http://i2.photobucket.com/albums/y43...2/site1081.jpg
I grounded the ecu, but there were no grounds in the ignition switch.
)@#($*)$(%&(*#$&%(*&!@)(#*!!! wiring
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/pBz_FZWkj4g&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/pBz_FZWkj4g&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
okay you can STOP watching after 30 seconds, then i just do laps around teh car.
Old Jun 19, 2009 | 11:28 AM
I'm glad I just watched you walk around the car like three times.
Sounds like either the starter is dead, or you have a bad battery connection...
Old Jun 20, 2009 | 10:20 AM
welp i took it to kragen and got the starter tested. GODD*** piece of **** solenoid was burned somehow. THATS JUST GREAT good thing i'm MADE of $110 bills. man this sucks
Old Jun 20, 2009 | 04:41 PM
by the way this is what happened with my starter situation. I went to get the solenoid repaired at RZ starter and alternators and I got there and he plugged positive and ignition and the damn starter ran like a well oiled machine. yep. then i went back to kragen on my way home still mystified how it wasn't working yesterday and he tested an it was PASS on everything. I made him do it two more times and it was perfect. So, why didn't it work in the first place? i have no idea. i really have no idea.
Old Jun 20, 2009 | 07:52 PM
Because it's probably your fubar'd wiring....
Old Jun 22, 2009 | 11:00 AM
possible ^^^^ also could be a burnt fusible link or a bad positive or negative wire on the battery since they hook directly to the starter. if your using the old battery terminal wires i'd replace them. then check the two fusible links right by the battery.
CaseyNuThang
Jun 22, 2013 08:43 PM
mystert85
Jun 16, 2012 07:37 PM
TiggerZ
Jul 8, 2011 08:25 PM
WanganDevilZ
Mar 26, 2010 03:46 PM
dowlinger
Jun 12, 2008 09:27 AM
