240Z, 260Z, 280Z Motor Swaps (non-V8) L28ET RB SR KA VG VQ 2JZ etc....
Snw's OFFICIAL 280Z turbo build thread - SMPYWD!
Old Feb 14, 2011 | 07:47 AM
  #126
ya, weird that the shifter seems further forward.
Good job keeping up with the progress though! How is the weather?
I'm back in sunny Seattle
Old Feb 14, 2011 | 10:08 AM
  #127
it is very weird. and yesterday the temp jumped up to 45 degrees and will be up there for a bit I believe
Old May 30, 2011 | 08:10 PM
  #128
skittle's Avatar
Taste My Rainbow
Looks like the engine is not sitting far enough back in the bay. Don't suppose you swapped the engine mounts around?
As far as the DS if its from a 75/76 then the rear diff uses a 2.25" flange with 10mm bolts, and the others had a 2.50" flange with 8mm bolts.
I found out the hard way when I had to get my DS shortened for my setup.
Old May 31, 2011 | 10:37 AM
  #129
skittle, The mounts can't be swapped around without SEVERE tilt in the engine. so that isn't possible. I know they had a wierd flange but I found one more extra DS laying around that was perfect. since then the car lit on fire lol... but.....
UPDATE FOR EVERYONE: I just got an entire body harness shipped to me, also found a 280ZX turbo for 300 dollars in kansas city, picking that up as well. will part it what I don't use and the S30 should be getting electrical power back into it. Hopefully I can bring it back to life.
Old May 31, 2011 | 07:01 PM
  #130
Superduner's Avatar
keep up the amazing work bro project is looking great. undergoing the project myself and im at the "wiring things up" electrically speaking and im having a nightmare.. no clue what i need to keep or i can remove to be able to run this car STOCK EVERYTHING weird how your tranny is sitting so far forward.. i kept the BG T5 on my swap and that baby is sitting RIGHT in the middle as it should not sure if its ok or not to post links in here but u can check mine out so far if youd like.
http://www.sdrev.com/forums/showthre...172#post324172
Not really doing anything fancy like you. wish i knew how to do all that waste-gate thing and good stuff haha. just keeping it simple. if its cool with u mind if i ask for some help or opinion if u reach a slump? we seem like were almost in the exact part of the swap. wiring things up.
Old Jul 15, 2011 | 01:25 PM
  #131
well, low and behold, got new wiring in it, and I noticed it trying to start... but it just wouldnt, then I looked down and thought, now why the hell didn't I plumb the intercooler system yet. so I did
and then the next thought clicked in my head, HOLY CRAP that's probably why it wasn't runing, becuase of the stupid AFM setup. and here it is...
http://www.youtube.com/watch?v=KIegVyUcUY8
BAM! listen to that turbo spool back down, can't hear it on the video as well spooling up. Take that randy and it's timed lol. just need to tidy up the wiring toss in the electric fan put fluids in it and get the interior together and it's ready to drive! also I think the FPR isn't holding pressure after shutdown.
Old Jul 15, 2011 | 02:51 PM
  #132
tonsoffun300zx's Avatar
West Coast!
im glad you got it up and running now you won't need the 240z so i'll just take it to texas and work on it on my 2 weeks off!
Old Jul 15, 2011 | 03:18 PM
  #133
evandubya's Avatar
Primer Grey FTW!
awesome job Snow!!!!!
Old Jul 16, 2011 | 10:52 AM
  #134
thanks. and i still woulda taken the 240z lol.
Old Jul 16, 2011 | 04:32 PM
  #135
West Coast!
i think im taking it to texas with my after i sell the z31t but if not idk maybe but i seriously haven't been to see my 240z for almost 6-7 months
Old Jul 17, 2011 | 02:42 PM
  #136
JSM's Avatar
JSM
So what did do wrong w/ the AFM? The ECU turned out to be fine?
Old Aug 5, 2011 | 02:08 AM
  #137
Awesome snow! It sounds pretty sweet! I am looking forward to the day, I have my own Turbo Z. It is going to be longer than I planned. All aside, glad you went back and tackled it, after that disasterous fire. Will keep checking on here for more progress. Keep up the good work bro'.
Old Aug 5, 2011 | 02:13 AM
  #138
When were you planning on going to Texas? And I still do want your 240z. How about swinging by my side of the desert on your way? heh heh
Old Aug 6, 2011 | 09:01 AM
  #139
I just didn't plumb the intercooler setup so it never started. I figured it would have started and idled without the AFM being hooked up to the turbo then to the intake manifold. but nope! and that was really the only issue. Now however the turbo is apart and awaiting a rebuild kit to show up because it was burning oil.
Old Aug 28, 2011 | 09:56 AM
  #140
Six_Shooter's Avatar
The F54/P90 combination was available in N/A form. That is currently what I have in my car, and have found out that it came from an '81 or '82 280ZX, from the research I have done. I have also ran upwards of 14 PSIG so far on it, both non intercooled and intercooled with no issues. I didn't run it at 14PSIG non-intercooled for long, since I saw the intake temps soar to 180 degrees F a couple times. I ran 12 PSIG non-intercooled for a few years until I decided I had enough time to build my IC. lol I am running a Delco ECM on it though, so I have plenty of control over fuel and spark.
The Automatic cars have a smaller shifter hole in them than the manual cars.
Automatic hole:
Manual hole (cut out automatic hole actually):
I had no problems using my automatic driveshaft with my manual tranny after the swap. There may be a king spline that needs to be lined up. I don't recall for sure though, since it has been a while since I had my driveshaft out.
I would add a support brace from the flange of the wastegate to the exhaust manifold. You have a fair amount of weight hanging off that tube, and with the heat could cause it to deform (bend), that could also cause leaks from cracking.
Old Aug 28, 2011 | 04:10 PM
  #141
thanks. I figured on the shifter hole, mines was cut open more months back. there was def a difference in some of my auto driveshafts but then I found one that worked so whatever i guess. I'm going to be running 8psi for now, then I think slowly build a megasquirt setup for next summer. I'll definitely look into a small brace, it's all getting TIG welded up now because I didn't like the looks of the welds on my wastegate setup I decided, and since it was all apart for the turbo to get a rebuild I figured why not. hopefully that's all back together this weekend and I can get the dash in, bleed the brakes and clutch, get all the lighting and gauges working and maybe I can actually take if for a spin around the block lol.
Old Dec 15, 2011 | 06:10 PM
  #142
so i technically finished this thing, but as some of you know it was burning a ton of oil, and it also seemed to run like sh#t under boost. soooo i did this
and got new these
arp of course, and new bearings.
and new these
just pistons, oem rods. got the crank in. finishing up the block tomorrow. probably have it running again this weekend possibly.
oh and When the head was off the old block, the ring gaps were like.030 so that was a big problem. got a different block, had the machine shop mic the bores and hone, new pistons and rings. all should be dandy this time. gap is tight! right in spec. .013
Old Dec 15, 2011 | 07:44 PM
  #143
skittle's Avatar
Taste My Rainbow
Very nice, I finally got mine up and running
http://www.youtube.com/watch?v=ZIbNZ6BVc5E
Old Dec 15, 2011 | 08:12 PM
  #144
JSM's Avatar
JSM
Spend some money there!
Old Dec 15, 2011 | 08:52 PM
  #145
Yes, and he means spend some money on non Home-Depot-kitchen-sink-hose for the oil catch can.
Old Dec 15, 2011 | 09:31 PM
  #146
JSM's Avatar
JSM
I've seen that on a few other cars too. Better then a garden hose!
Old Dec 16, 2011 | 12:33 AM
  #147
Sears hardware smart *** n don't act like youve never seen it before. It's to monster what's going through the lines. And custom made catch can with sight tubes. Works well. Still cost me 60 bucks in fittings hose n sheet metal. N Yah spent a little. But it'll be nice. Hopefully it fixes the crap missfire under boost too.
Old Dec 16, 2011 | 12:34 AM
  #148
Also I heard you sold my old 260z turbo. You're tge worst cousin ever for that. It was obviously fate to stay in the family haha.
Old Dec 16, 2011 | 05:16 AM
  #149
JSM's Avatar
JSM
Yep she is gone! Someone needed a car and I could use the extra $500 profit!
Was a clean car though. You gonna get a job in FL?
Old Dec 16, 2011 | 11:08 AM
  #150
Not sure yet very possible. Think my parents are buying a condo in ft. Myers though
