Rear Brake Adjuster not grabbing
Guest
Posts: n/a
My '71 Z's driver's side rear brake self adjuster is not working. The arm does not grab the teeth on the adjustment wheel. The only thing I can think of is to bend the arm some. I've had the car since 1978 but haven't driven it a lot lately. The back brakes haven't been changed in years and that's probably because they were not doing any braking. Does anyone have suggestions on how I should fix the adjuster?
Make sure that the star wheel thingy is well greesed and cleaned. Sometimes I have found that if this particular part isn't well lubed it will cause it to not grab and turn. So, first thing I would do if you haven't allready is to clean and lube.
I know that you do not want to hear this, but given the age of the car, I would order a New Hardware Kit, Cylinders, Rear Adjusters and Shoes. Then I would get busy! You might be able to disassemble the Adjusters and reuse as long as there is not a groove worn in the Adjuster. You can un-screw these assemblies and clean with a solvent of some kind and then re-lube with some high temp grease. Re-Assemble and adjust the Rear Wheel until you get appropriate drag on the Drum. Email me if you have questions.
Trancerror
Aug 2, 2010 03:44 PM
esancsufan
Jan 28, 2006 07:41 PM
