Rear Brake Adjuster not grabbing
Old Feb 4, 2005 | 05:37 PM
innerware's Avatar
Make sure that the star wheel thingy is well greesed and cleaned. Sometimes I have found that if this particular part isn't well lubed it will cause it to not grab and turn. So, first thing I would do if you haven't allready is to clean and lube.
Old Feb 28, 2005 | 02:02 PM
ZCurves's Avatar
I know that you do not want to hear this, but given the age of the car, I would order a New Hardware Kit, Cylinders, Rear Adjusters and Shoes. Then I would get busy! You might be able to disassemble the Adjusters and reuse as long as there is not a groove worn in the Adjuster. You can un-screw these assemblies and clean with a solvent of some kind and then re-lube with some high temp grease. Re-Assemble and adjust the Rear Wheel until you get appropriate drag on the Drum. Email me if you have questions.
Trancerror
Aug 2, 2010 03:44 PM
snwbrderphat540
Nov 6, 2007 09:46 AM
esancsufan
Jan 28, 2006 07:41 PM
AlansZ
Jun 12, 2002 10:11 PM
Skully
May 11, 2002 03:06 PM
