This is probably a silly question
Old Nov 4, 2005 | 11:52 PM
tinbender95's Avatar
But I gotta ask. Does anyone know how hard it would be to swap a 79 280zx 5 soeed tranny into a 71 240 with a 4 speed.
Old Nov 5, 2005 | 10:41 AM
Fairly simple. The only differences would be the exact location of the tranny mount & the driveshaft hook ups.
The tranny mount can be massaged to fit, but you might need a custom driveshaft.
Old Nov 5, 2005 | 06:15 PM
texasz's Avatar
It's a direct bolt in swap, the only thing may be that the shifter area might need to be cut out in the front (area nearest the radio) slightly for the stick to slide in to 5th properly. I have a '70 with a 5-speed and it works great!
This swap has been done hundreds of times, there's a LOT of information on the web about it if you decide to go forward with this upgrade.
Old Nov 6, 2005 | 11:10 AM
theramz's Avatar
I have a present for you...
You will need the rear trans mount from the '79. The shifter will hit the console a little and Tex is right, you will have to cut about 1/4 from the front of the hole. You can stretch the rubber boot and tek screw it in place. Your drive shaft will fit and it's a good time to replace the front and rear seals and the slave cyclinder.
sambway
Jun 9, 2012 11:38 AM
ever888
Aug 8, 2007 08:35 AM
thxone
Dec 24, 2006 11:24 AM
bardabe
Nov 11, 2005 06:44 AM
ensmuns
Oct 7, 2005 05:39 PM
