78 280z drum brake question?
Old Jun 5, 2014 | 12:49 PM
Tree_Stump's Avatar
I'm new to z cars and just picked up a 280z for $600. The back drum brakes where stuck. I took off the drum and what tearing them apart. I noticed that the wheel cylinders where different and was just wondering for that's normal for the 78 280z or should that be the same part?
Old Jun 6, 2014 | 03:22 AM
Steve260Z74's Avatar
Explain what you mean by different. There are left and right side cylinders.
Old Jun 6, 2014 | 11:05 AM
Tree_Stump's Avatar
They are two different parts. I was wondering if they should be the same part?
Old Jun 6, 2014 | 11:21 AM
Again... different compared to what??? Left cylinder to right cylinder? Different pistons on each side of the cylinder? What?
Help us help you...
Pics?
Old Jun 6, 2014 | 11:47 AM
Tree_Stump's Avatar
Yes the right wheel cyilnder compared to the left?
Old Jun 6, 2014 | 11:53 AM
Tree_Stump's Avatar
This is the left one
Old Jun 6, 2014 | 11:55 AM
Tree_Stump's Avatar
And this is the right one
Old Jun 6, 2014 | 12:52 PM
I erred earlier. The FSM shows a wheel cylinder only like the one you pictured in post #6. I verified part numbers and found only one for the wheel cylinder. This applies to 77 & 78 Zs.
Old Jun 6, 2014 | 01:56 PM
Tree_Stump's Avatar
So does that mean the guy before me must have messed around with the drum brakes? I just don't understand why they would be different.
Old Jun 6, 2014 | 02:57 PM
That's not a bad guess.
Old Dec 30, 2015 | 08:13 PM
zzznuts's Avatar
Post #6 (1st photo) is correct for left or right side wheel cylinder on a 1977-78 280Z. The lower photo was the earlier style which used a different wheel cylinder for left and right sides. New 77-78 Datsun Z wheel cylinder:
https://zcardepot.com/brakes/rear-br...80z-77-78.html
Old Dec 30, 2015 | 08:16 PM
zzznuts's Avatar
Somewhere in the past an entire assembly may have been pulled off of another car (earlier 70-76). It should work if you replaced all hardware, shoes & wheel cylinder.
Unknown Rider
May 13, 2015 11:38 AM
corbith
Dec 10, 2012 10:29 AM
Z Car Barbie
Jun 21, 2007 11:09 AM
Z Car Barbie
Sep 19, 2006 05:56 PM
s/cL3.0
16
May 2, 2005 08:52 PM
