Boring recommendations
Old Sep 23, 2009 | 09:57 AM
So here's my wear on the engine that I'm rebuilding.
Standard is 86.000 mm and here's what I have
Cylinders 1,2,3,5 and 6 are mic'd at 86.0425 and cylinder 4 is 86.0679 with the maximum wear being 86.1mm. What bore recommendations do you have for me, considering I need to buy new pistons and rings now that I destroyed my previous ones. Would a .5 mm overbore be too much? I'm going to buy ITM's pistons from a distributor right by my school. As for the boring and honing I might have a machine shop do the boring, or I might take a crack at it myself. Any tips or recommendations?
Old Sep 23, 2009 | 10:17 AM
If 89mm is not too much for the 3.1L stroker, then 86.5mm or 87mm isn't too much.
My point of view is to go 1mm overbore for two reasons:
#1: If you are going bigger, GO BIG... not just "kinda big".
#2: .5mm (.020) rings are (or at least used to be) hard to find.
Old Sep 23, 2009 | 10:18 AM
skib's Avatar
This facepalm's for you!
if your gonna bore and have to get new pistons might as well go out to 89mm
itl make it a 2.9L
(get a diesel crank and 9mm rods and youve got yourself a 3.1L stroker)
Old Sep 23, 2009 | 10:19 AM
^^^ lulz.
Great minds.....
Old Sep 23, 2009 | 10:35 AM
skib's Avatar
^^^ lulz.
Great minds.....
indeed...
and compared to an 86.5/87mm bore itl be easier to get pistons and rings too
89mm = KA24
Old Sep 23, 2009 | 11:24 AM
Is this going turbo, or are you just going to run it N/A?
KA has so many aftermarket for it it's nuts. 'If they don't make for your engine. make your engine for them"
Old Sep 23, 2009 | 11:56 AM
Second rebuild on his L28ET in his S30.
Old Sep 23, 2009 | 05:15 PM
just had to throw "second" in there didn't you ya bastard....
I've decided to go with .003" oversized from ITM obviously I have to bore it out, so should I bore it to .0028 and leave some for the hone? Or maybe .0026.
Thoughts....ideas....experiences? i'm all eyes
Old Sep 23, 2009 | 05:19 PM
skib's Avatar
dose that first one really count....
Old Sep 23, 2009 | 09:16 PM
.003" or .030" ? There's a big difference. Does ITM provide the ring kit for that size piston too?
Take the block, pistons, crank, and rings to the machine shop & say: please bore & install these.
Old Sep 24, 2009 | 07:25 AM
if only i could find the pistons i need. that's the largist part of my build. pistons.
Old Sep 24, 2009 | 08:28 AM
What size are you looking for?
Old Sep 24, 2009 | 09:52 AM
check your PM's
Old Sep 24, 2009 | 12:48 PM
well ITM doesn't have my pistons, they CARRY the standard, .02, .03, and .04 but NONE are in stock....
L31et?
sounds really FRIGGIN hard
Old Sep 24, 2009 | 12:57 PM
skib's Avatar
L31et?
its east but the crank would be spendy, but just doing an 89mm bore will make it a 2.9L
Old Sep 24, 2009 | 03:30 PM
Just as I imagined. Have you called MSA on these? http://www.thezstore.com/page/TZS/PROD/10-4033
Have you called Nissan?
Mar 5, 2012 02:09 PM
Niku-Sama
Oct 22, 2009 01:55 AM
91Zman
Apr 15, 2006 09:56 PM
DynamicJ
May 6, 2005 06:49 AM
laner
Feb 22, 2002 11:35 PM
