Rebuild Project
Old May 16, 2010 | 01:50 PM
  #51
Sounds like the timing is off...
And still no oil pressure?
Old May 16, 2010 | 02:13 PM
  #52
I JUST NOW got that issue fixed. I pull the pump and filled it clear full of oil and sure enough I got pressure!
And I have NO idea what the timing is at I still need to finish a few other things before I actually get it running for real. mind you thats the VERY FIRST time I started it lol
Old May 16, 2010 | 04:23 PM
  #53
Anyone know the fuel pump hose sizes for the in and out of the fuel pump? Sense I have a carb pump it will just be cheaper to get then a $75 returning FPR
Old May 16, 2010 | 08:46 PM
  #54
Also does anyone know what kind of air filter will fix in a 280ZX with SUs? I was thinking of MSAs K&N kit but that seems REALLY pricey...
Old May 20, 2010 | 05:26 PM
  #55
Ok well I started the break in today! All went well oil pressure was great! Temp barely even went over half but the timing was off a tooth lol I'm just gonna notch the Dizzy instead of pulling the pump.
I still need to re adjust the nozzles and float levels along with the air flow of the SUs a good bit but they seem to be working great! Tho I cant get my idle under 950RPM for some reason... maybe that will get fixed once I adjust the SUs
Old May 20, 2010 | 06:25 PM
  #56
Come on now son... do it right...
If you let the motor sit for at least an hour or two, you will have very little oil leak out. You'd have to cut the edge completely off the dizzy mount to get the timing right.
Fix the timing...
Old May 20, 2010 | 07:51 PM
  #57
I had the timing at 10 degrees (I took the bolt out) And it was still Idling high.
And To late I already notched the mount lol Bolts in and its at 10. So Im not gonna screw around with it anymore lol
Uh anyone have an SU Synchronizer that don't want anymore? lol Or one I can borrow for like an hour? I have one on the way but its like a week out (trying to save money where i can heh)
Old May 21, 2010 | 09:21 PM
  #58
I feel like showing off my Z again lol Tho its nothing pretty to look at
I'm not to sure I like the shifter I got
1st
N
2nd
Oh and see I notched the dizzy! it works great too!
Heh I was trying to do some cool body shots but I'm not so good with my camera anymore...
Yes my Z needs a bath lol
Old May 21, 2010 | 09:26 PM
  #59
Datsun!
I love the headlights on the early Zs
Someday, All black and hopefully racing seats oh and carpet too
OK No more photos
Old May 22, 2010 | 01:45 AM
  #60
And it should be known that I now know how to rebuild 280ZX speedometers!
I think I'll do a write up on this if no one else has yet. Its actually not that hard lol
Old May 22, 2010 | 10:47 PM
  #61
Got bored today and I needed to get a PCV filter on the valve cover. well I didn't feel like spending $20 on a K&N one so I made this and I think it looks pretty good. its a chevy PCV filter it works really well too lol
Old May 23, 2010 | 08:09 PM
  #62
From my tinkering w/ the 280zx speedo's, you just pull a retaining pin, lift a bar, and spin the dials back, right? I never installed one back in a car after spinning it to zero, mainly because I didn't want to take the chance at getting busted for altering the odometer. Though it should be fine if you plan to keep the car forever.
Old May 23, 2010 | 08:30 PM
  #63
Well pulling the pin out and spinning the gears is only half of it, you need to make sure the gears are still timed right else the thing jams up and started breaking stuff lol that and to use the right oil on the rod and gears and make sure the pin stop is in the right place and lotta little things
And If your car is exempt from odometer requirements it doesn't matter lol
Old May 26, 2010 | 12:30 PM
  #64
Well I got my stuff from MSA today! and I am a bit annoyed... The sycrotester does NOT work at all. But thankfully the K&Ns are ok tho they are an extremely tight fit in the engine bay...
Heh I drove it today and I ran into a really annoying issue with the fuel system I think its vapor locking as I drive it.... sense if I stop and let the fuel pump run with the engine off it will start and run again for a little bit, that or one of the 2 carbs it drinking gas faster then that fuel pump gives it and if thats the case, I might be washing my new rings out.... So I parked it till I get the new hopefully WORKING syncotester and get those carbs tuned right.
I'm kind regretting getting the carbs. Eh if worse comes to worse I'll sell them and the K&Ns and do a Z31 EFI swap lol
Old May 26, 2010 | 12:38 PM
  #65
Too bad I can't say "I told ya so". I'm usually very clear on my carb swap stance, but I kept my mouth shut for ya.
Anyway... I doubt it's vapor lock (I'm not sure why everyone jumps straight to the "It's vapor lock!" conclusion) unless it's somehow 100+ degrees in Vernal (It's 65* right now in Salt Lake). What are you using to regulate fuel pressure?
Old May 26, 2010 | 12:42 PM
  #66
Its been self regulated at about 4 PSI or so but maybe its not stable or something Revs find under no load when it does have load it coughs and stumbled and feels like its on 3 cyclinders.
And I figured as much but Oh well lol I'm hitting the junkyards this Saturday maybe I'll find a good Z31 to rip the EFI system out of.
Old May 26, 2010 | 06:16 PM
  #67
Ok I figured out that the fuel pump isnt keeping up with what the carbs need at higher RPMs so thats one issue.
Second is I got my syncrotester fixed and balanced the carbs and such but I cant get a stable smooth idle UNLESS I just LIGHTLY lift up the rear carb's needle piston... The needle and seat is spotless but I'm a bit confused
Old May 27, 2010 | 05:15 PM
  #68
K&N Air Filters and a nice set of NGK Spark plug wires! Everythings here now. Now I just need to fix the fuel issue and the odd idle issue and everything should be set! I'm thinking of ordering some Z Therapy Needles and Nozzles to replace the old ones and see if that helps with the idle issue. I'll probably reinstall the EFI fuel system and do a returning regulator setup so I can still have the fuel system do the 5 second prime and I have the safety shutoff still work!
On the side note, I have my old EFI system still boxed up just in case lol
Old May 27, 2010 | 09:07 PM
  #69
All that work and you didn't even get a header.
Old May 27, 2010 | 10:47 PM
  #70
I dont have enough for one lol I'm trying to save a little money where I can and I dont NEED a header lol
Old May 28, 2010 | 12:03 AM
  #71
Looks good man. But believe it or not. Headers are easier to mess with, opposed to the stock exhaust manifold. Man I forgot, how much of a pain the manifold is. Good luck man.
Old May 28, 2010 | 12:06 AM
  #72
I sorta figure seeing as its lighter and easier to get to the flange. but still funds didn't allow it and my manifold still works so....ya lol
Tho they would look good with everything else on the motor...
Old May 28, 2010 | 12:18 AM
  #73
^ Yes they would. But funds can be a problem. Luckily, I got these headers, when I bought my '81 10 years ago. So that helps. You can get a pair, and put them on later. No big deal. I do love the sound, and smoothness they have.
Old May 28, 2010 | 12:36 AM
  #74
Ah nice! Heh maybe someday I'll get them but I have more important things I need to get first annoyingly...
Old May 28, 2010 | 10:35 AM
  #75
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I love being able to reach around that side of the motor about 5 minutes after shut down and not have to worry about burning my hands... The sound and all that is nice too.
