How to tell if is a Stroker engine?
Old 08-28-2015, 07:56 AM
Rynbernsz's Avatar
Question How to tell if is a Stroker engine?
I bought an '83 280zx. The guy says it's a 3.1L Stroker engine. How can I tell?
Thanks!
Rynbernsz is offline
Old 08-28-2015, 07:59 AM
With the paperwork, or tear into the engine. You can't tell just by looking at the engine.
You'd have to drop the oil pan and make sure the crank says "V07", and/or remove the head and measure the cylinder width. If it is truly a stroker, there are probably a lot of changes to the car... post some pics.
NismoPick is offline
Old 08-28-2015, 08:07 AM
Rynbernsz's Avatar
Thanks NismoPick! I'll get into it soon, keep y'all updated and try to get some pics up of it, as well.
Old 08-28-2015, 09:09 AM
Rynbernsz's Avatar
What lettering would there be if it is still stock?
Old 08-28-2015, 10:07 AM
Lettering on the crankshaft you mean? Anything that's not "V07".
https://www.zdriver.com/forums/sale-...ank-vo7-37984/
Old 08-31-2015, 06:44 AM
Rynbernsz's Avatar
I tried a different method because I was worried if about resealing the oil pan after taking it out to get to the crankshaft.
I researched and found that the piston stroke length of an l28 stock is 78mm. A stroker modification from 2.9L - 3.1L is 83mm.
I took a spark plug out and stuck a stable metal wire down the spark plug hole. I put the car in 4th gear, which I heard was an easier gear to roll with. We rolled the car until the piston went all the way down and marked it. then rolled it back the other until the piston went all the way up and marked it. Measured it and got 83.22mm. So with some leniency on the measuring, we'll say it's a Stroker!
widebodyz
08-03-2008 08:13 PM
byrneZ
16
01-28-2008 02:04 PM
ThermalWake
09-28-2005 09:37 AM
Adz260
06-20-2003 02:11 PM
perfectindustry
10-24-2002 02:31 PM
Quick Reply: How to tell if is a Stroker engine?
