rear camber
Old Apr 17, 2006 | 08:58 PM
rob209's Avatar
rear camber
so my rear tires are in dire need of camber adjustment so I bought the rear camber arms and toe adjusters by SPC and they should be here tomorrow. what specs should I give the alignment guys for a happy medium between the track and drag racing? drag you want a camber of 0, so your tire is straight up and down. right now they are far from that. noted, my track tires are 17" and drags are 18" - does that mean the camber may be diff for each tire? i think i'll end up with a semi-track setting, that can be neutralized somewhat by raising my rear springs.
anyone recommend a good alignment place? that can also install the camber arms?
Old Apr 17, 2006 | 09:03 PM
Nforce1's Avatar
Im in the same spot as you, I just lowered my car and the camber is way off.. I dont want to eat up my new rear tires. Im trying to figure out what camber kit to get. Can anyone really tell me the difference between say... Ebay and SPC? for the most part, they both do the same job right?? any imput? Being broke sucks, but I want to get this fixed so I dont spend another pretty penny for new tires in 5000 miles.
Old Apr 17, 2006 | 09:35 PM
roneski's Avatar
I'm running 3 degrees in the rear but I'm set up mainly for the track. If you want to balance between track and drag racing I'd look at going to 1.5 degrees then take it to the drag strip and see how well you hook up. I'f you're still looking good then add a little more.
3 degrees is actually a little high and I wouldn't recommend if especially if you drive your car every day. You will definitely get some uneven tire wear.
Old Apr 18, 2006 | 07:32 AM
rob209's Avatar
The SPC is only $200 - I figured it wasn't too much more for knowing it will work and having a warranty. It's been proven on my350z.
Old Apr 18, 2006 | 10:38 AM
SinCity350Z's Avatar
Las Vegas Moderator
Aarif - The difference between eBay and SPC is that SPC wont break and will fit right lol.
Rob - See if you can get two different settings and mark it on the camber arms. One at 0 degrees and one a say -3 degrees. I know a few guys on the forums do that and change the camber when they change between street & track tires.
Old Apr 18, 2006 | 10:45 AM
ensmuns's Avatar
Vegas 350Z Moderator
Addition to Aarif - Since you don't track or race your ride, I'd strongly suggest you take it back to Nissan (Planet will do it) and have them set your camber and alignment back to factory specifications. You don't need the SPC camber/toe adjuster; you'd just be wasting money. You can get the alignment/camber adjustment done for $99 + tax, get your car washed, and then get it back in about an hour and a half.
<--- And oh yeah... my 1,200th post!!!!
Old Apr 18, 2006 | 12:54 PM
rob209's Avatar
That's it.
What about toe?
Old Apr 18, 2006 | 12:55 PM
Las Vegas Moderator
Do the same for the toe, although it shouldn't be affected much, if any.
Old Apr 18, 2006 | 03:41 PM
rob209's Avatar
appt at George's alignment on Meade ave on Thursday morning... anyone been there before?
Old Apr 18, 2006 | 03:43 PM
Las Vegas Moderator
I haven't been there, but I heard that its the place to go.
Old Apr 18, 2006 | 03:49 PM
roneski's Avatar
I've been there. They are low tech, but do pretty good work.
Old Apr 18, 2006 | 05:16 PM
Nforce1's Avatar
I think ill go to georges too... I got that recommendation also.. im gunna do my brakes, change my tires and then go for my alignment
Old Apr 20, 2006 | 10:50 AM
rob209's Avatar
went by there this morning after installing my new SPC camber arms last night. basically, right now my rear is at 3 degrees, and the front is at 2.5 degrees. the guy said come back after i want to get a street setting, but right now i'm set great for the track. no changes made.
no charge.... how often does that happen? dealerships charge you for driving on their property.
Old Apr 20, 2006 | 11:09 AM
roneski's Avatar
The guys at Georges are way cool. I paid for my first alignment but they said that I could come back for free adjustments if I didn't like the way it was behaving at the track.
Old Apr 23, 2006 | 01:49 PM
Nforce1's Avatar
So Im really debating on getting a camber kit. I have some pretty bad negative camber. But getting an alignment can fix this?? Just looking I dont see how getting an alignment can fix this negative camber. I want it back at 0 camber because Im putting new tires on and I dont want them ate up. So.. question is, buy camber kit or not?
Old Apr 23, 2006 | 04:00 PM
rob209's Avatar
do it. i got the SPC kit and installed it myself with no problem. around $200.
Old Apr 23, 2006 | 06:32 PM
Las Vegas Moderator
buy the kit, install is a snap and they are relatively cheap.
Old Apr 23, 2006 | 06:36 PM
Nforce1's Avatar
Link where you bought them rob??
Old Apr 23, 2006 | 06:40 PM
Las Vegas Moderator
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
$227 shipped. I don't know if thats where Rob got his though.
Old Apr 23, 2006 | 09:50 PM
rob209's Avatar
^^^ that's it.
Old Apr 23, 2006 | 10:14 PM
Nforce1's Avatar
thanks guys
stevek247
Feb 28, 2013 09:36 AM
johnZboy
Jun 8, 2009 10:26 PM
Turbo86
Mar 14, 2007 08:40 AM
thxone
13
May 12, 2006 12:18 AM
85TurboZ
13
Mar 6, 2004 04:26 PM
