Brake help
Old Nov 29, 2006 | 03:48 AM
Smittyz33's Avatar
Brake help
Maybe something for the next tech session, but i'll ask the question.
My Wilwood kit is screaching...loud doesn't even begin to describe the noise. I tried different pads, that didn't work.
I tried shims and the system was so compacted the brakes were continuously engaged.
Nissan installed the kit and reevaluated it after the screaching started and they said it was the pads. I've tried two different compounds.
Most recently, I had my buddy remove the rotors and have them turned (they were slightly warped anyway) and ground.
With each step, I ensured I followed Wilwoods break in procedure.
Anyone have time to stop buy and try and diagnose before I have someone rip them off and toss them in a pulverizer?
Old Nov 29, 2006 | 06:16 AM
SinCity350Z's Avatar
Las Vegas Moderator
The only thing I can think of is the pad compound. Track pads and things of that nature squeal like a pig when cold.
Old Nov 29, 2006 | 06:27 AM
Yogi's Avatar
A school bus w/ bad brakes?
If that's your sound then Mikey hit the nail on the head. You'll have to try to find a street compound that fits and put a little antisqueal on the back of the pads.
Another option is to heat up the brakes enough until they don't make noise.
Old Nov 29, 2006 | 06:31 AM
Las Vegas Moderator
Ooooohhh, thats the worst noise on earth.
Old Nov 29, 2006 | 09:03 AM
Nforce1's Avatar
Funny, just as I read that line... a school bus with bad brakes was outside my window stopping. llol
Old Nov 29, 2006 | 09:07 AM
i8acobra's Avatar
That's not a good idea with Wilwoods. The pistons don't have a dust seal, so the anti-squeal could get between the piston and the caliper.
The squealing is caused by the brake pad compound. The noise is caused by the pads gripping and releasing at a high frequency. Usually this means your pads aren't getting hot enough. Try a more street oriented compund. Most brake manufacturers make pads for Wilwood calipers. They don't have to be Wilwood pads. Try some EBC Greenstuff's or Hawk HPS's for the street.
Old Nov 29, 2006 | 09:57 AM
Las Vegas Moderator
Even the Hawk HPS squeal a little. I have them in the G.
Old Nov 29, 2006 | 10:59 AM
Love2ridepow's Avatar
My HPS have been squeeling since day 1, hell, even my OEM pads did, but not "school bus" style.
Old Nov 29, 2006 | 12:32 PM
roneski's Avatar
I've never had a problem with my HPS.
Old Nov 29, 2006 | 04:02 PM
Smittyz33's Avatar
Its so loud that its undriveable...i'll order some other pads. The ones i've tried are WW BP10 and BP20 compounds.
Pipsqueak
15
Mar 22, 2012 08:45 PM
williamsr.91093
Jun 6, 2011 03:31 PM
Tsuka89
Jun 5, 2011 12:58 AM
82280zxt
May 13, 2003 09:19 AM
onelegmurphy
Nov 12, 2002 08:26 PM
