E-Brake
Old May 13, 2010 | 08:09 AM
williamsr.91093's Avatar
E-Brake
I need to know how to tighten the E-brake on a 300zx. Can anyone help?
Old May 13, 2010 | 01:46 PM
nismo619's Avatar
You will have to jack the car up and look underneath the car for the bolts that unlock an tighten the cable that connectes between the ebrake handle an the rear cable.
Old May 25, 2011 | 07:22 AM
SoNotaMechanic's Avatar
What if my drivers side brake isn't tightening? The passenger side is a bit loose too. I've already tightened the cable as tight as it gets. Do I need to cable?
Old May 25, 2011 | 10:57 AM
AZ-ZBum's Avatar
Most likely. Disconnect the cable from the brake caliper and see if it slides smoothly. Chances are it doesn't.
Old May 25, 2011 | 12:05 PM
See if the cable slides smoothly or the caliper? I really need a new cable.
Old May 25, 2011 | 05:15 PM
AZ-ZBum's Avatar
Both actually.
Old Jun 6, 2011 | 03:31 PM
pMetal's Avatar
I just had to do this on my '93 Z. In my case, on one side the e-brake shoes had rusted solid, and on the other side the e-brake cable rusted solid into the sheath end where it enters the brake housing.
Here's how I fixed it:
For the rusted non-moving brake shoe, I just had to break it free by prying the moving parts apart with a giant screwdriver. Then I coated all of the mating surfaces with brake caliper/shoe grease.
For the side with the rusted solid cable, I completely dissassembled the parking brake shoe (take careful note of what springs go where, etc.) and then unbolted the cable from the brake housing so that I was able to feed the cable out of the brake area. I scraped away all the rust I could, sprayed it with WD-40 and then gave a good tug of the e-brake lever. This broke the cable free. Then I scraped off all the now-loosened rust, thoroughly coated all moving parts with brake caliper/shoe grease and reassembled everything.
Also, its worth noting that you can trace the cable underneath the car if you jack it up and put the car up on 4 jackstands. By feeling where the cable is loose or tight when the lever is pulled you can identify where your restriction is.
Now, with regard to calibrating the e-brake, the service manual says to expand the shoe until it makes contact (stick a screwdriver through the little hole in the rotor while the hole is lined up with the adjuster at 6 oclock) and then back of 5 or 6 clicks.
Pipsqueak
15
Mar 22, 2012 08:45 PM
Tsuka89
Jun 5, 2011 12:58 AM
CollectorKid
Oct 13, 2004 09:59 AM
82280zxt
May 13, 2003 09:19 AM
onelegmurphy
Nov 12, 2002 08:26 PM
