Brake help
Maybe something for the next tech session, but i'll ask the question.
My Wilwood kit is screaching...loud doesn't even begin to describe the noise. I tried different pads, that didn't work. I tried shims and the system was so compacted the brakes were continuously engaged. Nissan installed the kit and reevaluated it after the screaching started and they said it was the pads. I've tried two different compounds. Most recently, I had my buddy remove the rotors and have them turned (they were slightly warped anyway) and ground. With each step, I ensured I followed Wilwoods break in procedure. Anyone have time to stop buy and try and diagnose before I have someone rip them off and toss them in a pulverizer? |
The only thing I can think of is the pad compound. Track pads and things of that nature squeal like a pig when cold.
If that's your sound then Mikey hit the nail on the head. You'll have to try to find a street compound that fits and put a little antisqueal on the back of the pads. Another option is to heat up the brakes enough until they don't make noise. |
Originally Posted by Yogi
A school bus w/ bad brakes?
The squealing is caused by the brake pad compound. The noise is caused by the pads gripping and releasing at a high frequency. Usually this means your pads aren't getting hot enough. Try a more street oriented compund. Most brake manufacturers make pads for Wilwood calipers. They don't have to be Wilwood pads. Try some EBC Greenstuff's or Hawk HPS's for the street. |
Even the Hawk HPS squeal a little. I have them in the G.
My HPS have been squeeling since day 1, hell, even my OEM pads did, but not "school bus" style.
I've never had a problem with my HPS.
Its so loud that its undriveable...i'll order some other pads. The ones i've tried are WW BP10 and BP20 compounds.
