2006 350Z door panel removal
Old Mar 22, 2007 | 08:11 AM
istan's Avatar
I8acobra should have the directions.
Old Mar 22, 2007 | 08:37 AM
ensmuns's Avatar
Vegas 350Z Moderator
DRIVER DOOR FINISHER
Removal
1. Remove cap inside handle portion and remove screw.
2. Remove finisher power window main switch.
3. Disconnect harness connector power window main switch.
4. Remove screw of power window main switch portion.
5. Disengage both of the door main harness clip on the rear surface of the door finisher.
6. Disengage part of the bottle holder's illumination harness connector.
7. Pull up door finisher and remove connector inside handle cable and lock **** cable.
Installation
Install in the reverse order of removal.
CAUTION:
To install finisher, check if all clips are matched over holes of panel on vehicle, then push it.
PASSENGER DOOR FINISHER
Removal
2. Insert taping flat-bladed screwdriver into edge portion, disconnect pawls, and remove door grip finisher.
3. Remove screw of door grip portion.
4. Remove finisher power window sub switch.
5. Disconnect harness connector power window sub switch.
6. Disengage both of the door main harness clip on the rear surface of the door finisher.
7. Disengage part of the bottle holder's illumination harness connector.
8. Remove screw of power window sub switch portion.
9. Pull up door finisher and remove connector inside handle cable and lock **** cable.
Installation
CAUTION:
Old Mar 22, 2007 | 04:32 PM
istan's Avatar
PM sent........
Old Mar 22, 2007 | 09:39 PM
istan's Avatar
Credit goes to I8acobra. He sent me the link
Old Mar 23, 2007 | 04:17 AM
ensmuns's Avatar
Hmmm weird. Those directions were from the Aug 2005 revision of the 2006 350Z Service Manual downloaded from 350Z-Tech.com. Oh well. I tried.
Old Mar 24, 2007 | 07:10 PM
Tobizach's Avatar
Its the thought that counts chris
Old Mar 26, 2007 | 08:29 PM
istan's Avatar
Did the new manual work?
Vedivan
Mar 19, 2013 09:07 PM
rogerz
Sep 28, 2011 11:27 AM
my86z
Apr 13, 2008 03:54 PM
rupert42
Mar 26, 2004 08:44 PM
insomniac67j
Jun 19, 2002 08:28 PM
