new camcorder need help
Hey guys, just picked up this little gem, Panasonic GS31
now I want to connect this thing to my PC to do a little editing, but I cannot figure out what cable I need. I know a lot of you guys (nismopick, etc,) are into capturing video, but I am very new to this. anyone able to point me in the right direction? As far as I know, I guess there is a cable that I can plug from the camcorder straight to a usb port??
jason
jason
Looks like according to the specs from CC, it uses either a USB or Firewire port (IEEE 1394). Just hook your camera up to the USB and it should recognize it. It may do a little driver or application loading process when you first hook it up, thats just to let your computer see the device. Once the OS sees it, you should be able to access all of your video files by going to My Computer and clicking on your video camera icon (the video files may be in a subdirectory).
Sorry, I don't have much experience with VIDEO cameras, but quite a bit w/ digi/vid cameras, and none w/ Panasonic. It sounds like the same basic process: Just hook it up (USB in your case), Let the computer find it, Open the video camera folder/directory, Select video. Hope this helps, good luck
EDIT: If your computer doesn't automatically see it, you may have to install some software that came with it, many new cameras and camcorders don't require you to install software, but some still do. Or if you are using an older system w/ a USB (older than 5 years), you may have to instruct your computer to look for a new device on that USB slot. Being that this is a new camera, and I assume your using a new-ish computer, they should see each other automatically...
if the video is recorded on mini dv tape, you have to capture it in real time. usb isnt fast enough for that. my dv cam can also record short vids to memory sticks, and it can capture from the mem stick with usb because it doesnt have to be real time, and its a more compressed format. firewire is fast enough for real time capture from mini dv.
LoL, proof that I don't know much about video cameras. It is a good point, I would also recommend going w/ a Firewire plug (if your computer has one). I think Entropy is right, USB wouldn't be able to do any Real Time video, it is really probably ment for still images, and short videos that are on the storage card.
yeah. I've got a pretty powerful system. I just don't have one of those firewire ports (i think) I am pretty new to this whole thing. my camcorder has a slot for an SD card, but I figure it would take a pretty large one, and Im not too thrilled about spending 100 bucks on a 1 gig SD Card
