Australia Serving Australia.
240SX Intake and throttle body
Old Sep 17, 2004 | 02:59 AM
Menza's Avatar
hey all,
does anyone know where i can get a 240SX intake and throttle body? here is the specs for the motor "89-90 single cam ka24e 240SX with cruise control"
hope someone out there can help me.
cheers
Old Sep 26, 2004 | 03:15 PM
Beauz 84'NA's Avatar
why not do it urself
hey man, i think you've ogt the same idea as me, putting a 240sx throttle body on your z31, i've got an 84 NA, what's yours?
I don't know where you can get 240sx stuff in Oz, but i was gonna get a bigger throttle body than a stock Z31, ans simply make an adapter plate to fit to the intake collector and grind out the inside of where the throttle body meets the intake collector for smooth airflow. so why not do that urself?
hope this helps
Old Oct 4, 2004 | 02:58 AM
nitr0's Avatar
Originally Posted by Menza
hey all,
cheers
I'm currently installing a 68mm TB from the XD/XF Falcon, bolt pattern is almost identicle although i got a plate welded on. Havent got it installed yet, but I'm mechanically retarded and its seems pretty basic to me, so someone with a bit of knowledge should be able to do it in an afternoon.
http://202.76.146.37/~nitro2/tb1.jpg
http://202.76.146.37/~nitro2/tb2.jpg
http://202.76.146.37/~nitro2/tb3.jpg
http://202.76.146.37/~nitro2/tb4.jpg
The 2 holes on the AFM side of the TB need to be blocked or used - i'm using my for vacuum hoses. You will also need to make up throttle linkage and bypass your Air Regulator (i think), errr you will also need to join the water hoses that go through the stock TB and remove the idle adjuster on some models (the XF TB comes with idle adjustment).
Oh yer and dont forget TPS, replace your AFM with something bigger, since thats the next bottleneck, and make sure you port your intake RIGHT out, mines somewhere between 62 and 65mm.
hope this helps
Later edit: i just realised you guys are talkin about z31 lol, that intakes from an L28. Still, the XF TB might work
Old Oct 4, 2004 | 11:13 AM
91zxtt's Avatar
I installed a 240SX TB on my Z31 when I owned it 5+ years ago. The 240SX TB is 60mm. I believe the stock Z31 is 52mm. It was a direct bolt-on fit. There was an extra vacuum line on the 240SX TB; which needed to be plugged. You also had to grind out the inside of the plenum so that it would increase the airflow capabilities of your Z31 plenum. I had an '85NA, so the HP gains were minimal, but it did seeme to make a difference.
You can probably get a TB from an auto-wrecker or salvage yard.
Old Oct 4, 2004 | 11:36 AM
GodZilla's Avatar
Banned
I have a 240SX TB I could sell you..
PM me for info
Old Oct 4, 2004 | 12:03 PM
Spudz's Avatar
My Buddy made an adapter , so he can use the throttle body of a big block Chevy.
I believe these are 70MM bodies. He does have to port the intake to make it flow better.
Mike
Old Jan 27, 2005 | 01:06 PM
DoTheDrew888's Avatar
What year 240SX do you pull it off of for an L28?
MMiskoe
FS: 300ZX (84-89)
Dec 5, 2014 02:44 PM
zlaxbro
Feb 1, 2013 03:11 AM
KTM200-280zxt
Oct 19, 2006 11:37 AM
KTM200-280zxt
Jul 18, 2006 10:12 PM
cerealkilla
Aug 31, 2003 09:01 PM
