350Z Performance / Technical Discussions related to Turbo charging, Supercharging, Engine, ECU, exhaust, and etc. performance enhancements and Techical related.
Loud Shreaking sound when i start the car and when I drive
Old Feb 29, 2004 | 02:44 PM
emo236's Avatar
confuzed member
Does the sound stay there? Or does it go away after like 5 minutes or less? If that's the case, it's your timing belt tensioner. It's more of an annoyance than anything. Replace it next time you do your 60K. If it stays, then it's belt. It could be your timing belt, accesory belt, etc. It's probably loose or the pulleys aren't very well oiled. Oh, and I suppose your somewhat new to this, but this is the 350z section, you'll get more of the help you need if you post in the z32 (300zx) section right beneath this one. Hope that helped...feel free to ask for any questions.
Old Mar 1, 2004 | 08:56 AM
91zxtt's Avatar
Try tightening your accessory belts (ac, ps, wp). That is more likely than your timing belt squealing. You could also try spraying a cleaning solution (simple green, etc.) on the accessory pulleys while the car is running. It will clean any oil or grease off of the pulleys; which could cause the belts to squeal also. I don't think having your car in gear or out of gear should make a difference. It's probably just a coincidence.
Old Mar 1, 2004 | 10:33 PM
Riz Z Speed's Avatar
Administrative Brown Guy
There's actually a belt dressing that is sold in most auto parts stores for that instead of using something like simple green. Most cleaning solutions like that will end up drying out the belt further, promoting cracking and eventually breakage.
kody352
Apr 17, 2014 10:55 PM
TiggerZ
Jul 8, 2011 08:25 PM
TiggerZ
Jul 7, 2011 07:02 PM
duowing
Nov 21, 2005 02:24 PM
Hrududu
Nov 21, 2005 12:56 PM
