Z32TT Suddenly No Boost
Old Sep 5, 2013 | 07:10 AM
naterbader73's Avatar
I have a 1994 300zx twin turbo. Some of the mods I have are Cold air intake. Jim Wolff ECU, Exhaust System and intercooler which was the last thing I put on about 2 weeks ago. O ya Turbo timer. Well Here is the story. Last weekend I got in my car and let her warm up and went out in her and started my day. I noticed the my PSI on my turbos was around 7psi when normally they are at 11psi. Well I hop on the freeway and about 15 min on the freeway when I get off the exit I noticed that all my boost was gone. So I take my care back to my place and run the code and it pulled up a code 34. Well I talked the previous owner of the car and he made me aware the knock has been relocated in a different location and was done. The motor purrs like a kitten. No knock or any noises. So I put some fuel treatment in to clean out the fuel just encase it may of been that. Cleared the code and got a 55. Well it has stayed on code 55 but still have no boost and stuck in limp mode. So can anyone out there tell me what I need to check? And if me adding the center intercooler what of done this?
Old Sep 5, 2013 | 12:42 PM
I'd start with checking the vacuum lines to the boost sensor and intercooler piping / connections. If you normally run 11psi boost, do you have boost jets or an electronic boost controller?
Old Sep 5, 2013 | 03:41 PM
Rupe's Avatar
Horsepower Mathematician
I've got to ask just in case, does it actually feel like you're not getting any boost?
Old Sep 7, 2013 | 05:39 PM
Ya.. It doesn't feel like any boost... And I have no boost controller
Old Sep 7, 2013 | 05:55 PM
One thing I forgot to add ... When we put the intercooler in the cold air intake filter I had on there before we put it on would not fit. So we had to put a shorter filter on it to make it work. Not sure if that would mess with the mafs. Also the intercooler I purrchased is a Godspeed... Not sure if they may be it.
davidjoe007
Mar 7, 2023 09:28 AM
VanBruno
Nov 2, 2014 10:16 PM
papito
FS: 300ZX (90-96)
Jul 12, 2012 05:45 PM
1SIKZ
Mar 12, 2006 11:39 AM
jtmny1999
Apr 3, 2003 07:40 PM
