Z help needed
Old Nov 24, 2007 | 02:23 PM
Raisanbran's Avatar
Z help needed
I would really appreciate any help i can get.
My Z (91 n/a) is bogging down hardas in it wont rev above 3rpm and do around 20mph max before it starts dying. Its also backfiring when its reved and just feels like it has no power. I just bought the car so i dont know much about them yet but the only thing done to it is full monza exhaust, oh btw it gave code 55 when i checked the ecu.
Old Nov 24, 2007 | 03:04 PM
b300z's Avatar
caught the z fever
welcome to the site
please use the search function before asking a question. many topics, such as this one, have been covered many times before
do this first
http://www.ttzd.com/tech/diagnostictech.html
and the go thru this thread. it has tons of helpful information on the 2nd page.
https://www.zdriver.com/forums/showt...=lost+of+power
Old Nov 25, 2007 | 11:02 AM
CanyonCarver's Avatar
Jack Of All Trades
Learn some punctuation too.
Old Nov 25, 2007 | 10:52 PM
Raisanbran's Avatar
Hey i posted for some insight on my problem not ******** comments
Ive tied forums, ive read through em all, i got a code 55 , ive checked everything i can think of and still cant come up with whats wrong
Old Nov 26, 2007 | 07:29 AM
b300z's Avatar
caught the z fever
we have said nothing out of the ordinary for a new z owner.
tell us what you have tried, any maybe we can help you more. i doubt you have tried everything
Old Nov 26, 2007 | 09:37 AM
ViperGTO99's Avatar
Raisan... They're not "******** Comments"... It rules you have to follow to get ANY respect on this site. I learned quick, you should try to do the same. Don't Swear, use correct punctuation,(this isn't a text message, so none of that crap) and don't try to be a smart@$$ with the guys that you're trying to get help from.
Now, SEARCH... The problem has been talked about alot. Just limit your search to Z32 and use the same key words you're giving us now. We're all here to help, but we shouldn't have to type the same thing 10 times.
Oh, Welcome to the site. There's alot of information here for you... just learn how to find it.
Old Nov 28, 2007 | 09:00 PM
91zxtt's Avatar
When did schools stop teaching grammar and when did parents stop teaching manners? Calling CC a ******** won't get you anything more than banned on this forum. Change your attitude or find a new forum.
Old Nov 28, 2007 | 10:24 PM
SpeciallySpiked's Avatar
I'm a Registered User!
soo... you didn't click on his link then did you?
ECU
LED codes for MODE II:
11: crank angle sensor circuit
12*: air flow meter circuit
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
21: ignition signal circuit
26*: boost pressure sensor
31*: ECU
32*: EGR function
33*: exhaust gas sensor circuit (left)
34: detonation sensor circuit
35*: exhaust gas temp. sensor circuit
42: fuel temp. sensor circuit
43*: throttle position sensor circuit
45*: injector leak
51*: injector circuit
53*: exhaust gas sensor circuit (right)
54: signal circuit from A/T control to ECU
55: NO malfunctions in the above
Old Nov 29, 2007 | 08:32 AM
b300z's Avatar
caught the z fever
ECU
31*: ECU
32*: EGR function
45*: injector leak
wat? im confused
Old Nov 29, 2007 | 09:37 AM
I just posted what you posted on the ECU codes and their meanings. It looked like he still didn't read what you had posted when he mentioned again that he's getting a code 55.
I guess might as well as the 280ZX question for this problem....
Did you wash your engine bay recently? If so you might have some water in your connections there...(don't know if that works for 300ZX's)
Old Nov 29, 2007 | 09:49 AM
b300z's Avatar
caught the z fever
he edited his original post after i had put the ECU diagnostic link in my post
Old Nov 29, 2007 | 10:16 AM
cars running that rough usually dont toss a all good code on the ECU. sounds like a major sensor failur and its in safe mode, or cant run right with out it.
Old Nov 29, 2007 | 04:20 PM
KasbeKZ's Avatar
Pr0n Addict
my 3000GT friend is always all paranoid about the ECU failure that they suffer because of something leaking down onto the board in the ECU. I'm looking into the possibility that this could happen in our 300zx's. it causes false readings and false outputs. (not that i would dare degrade a 300 to the lowness of a 3000... no offense...)
Old Dec 1, 2007 | 02:11 AM
Z Car Barbie's Avatar
User Friendly
Welcome, Raisanbran! We're sorry if you were offended by the previous comments, but proper punctuation and grammar really does help us in trying to read and understand the problem so that we can help more efficiently.
I would have to agree with Snowie on regarding the Code 55. Would you please try to run the ECU diagnostics one more time, just to make sure there's no error codes?
Sometimes you'll get no error codes if the procedure isn't done properly. Re-running the codes will help save you a lot of time in trying to figure out the problem, and reading our diagnoses of problems that might not even be relevant.
Old Dec 1, 2007 | 01:05 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
It's probably the fuel system. Pump failure can cause this problem, as well as a bad pressure regulator or dampner. Search and you'll find one of my many writeups on how to diagnose these. (Advanced search terms like "fuel system" by ZLover4Life, you should be able to find it.)
Jason C.
Dec 18, 2005 08:08 PM
jfairladyz
Nov 9, 2005 04:54 PM
leftlanelunatic
Nov 27, 2004 11:05 AM
Spudz
Oct 3, 2004 08:59 PM
xxdrholidayxx
Aug 17, 2002 08:38 AM
