help needed
Old Dec 17, 2005 | 08:27 PM
Jason C.'s Avatar
help needed
i'm still having computer problems with my 83 zxt, and i know someone who is parting out an 81 zxt. now i know the ecu's aren't interchangable, but can i take the ecu,the wiring harness, and all of the associated sensors and stuff off of the 81 and make it work on mine. if so how hard would it be.
Old Dec 17, 2005 | 10:00 PM
lww's Avatar
lww
Head Muckraker
The 81 uses a crank angle sensor to trigger the ignition and the 82/83 does not.
You can make it work, but it becomes a lot more involved.
I would keep looking for an 82/83 Turbo ECU.
Old Dec 18, 2005 | 10:30 AM
lifegrddude's Avatar
Externally Wastegated
Also, I think the 81 turbo ecu has dropping resistors used so it will not work with an 82-83 along with the different CAS mentioned above. You can use the afm and other small sensors though. Those are all the same.
Old Dec 18, 2005 | 04:02 PM
Jason C.'s Avatar
the ecu that is in the car now is from an 82zxt instead of an 83 and its running bad, can i get the wiring harness and sensors from an 82zxt and make it work.
Old Dec 18, 2005 | 08:08 PM
Jason C.'s Avatar
nevermind guys, i think i just located the right ecu for my car. thanks anyway.
Raisanbran
14
Dec 1, 2007 01:05 PM
jfairladyz
Nov 9, 2005 04:54 PM
leftlanelunatic
Nov 27, 2004 11:05 AM
Spudz
Oct 3, 2004 08:59 PM
xxdrholidayxx
Aug 17, 2002 08:38 AM
