Z help needed
I would really appreciate any help i can get.
My Z (91 n/a) is bogging down hardas in it wont rev above 3rpm and do around 20mph max before it starts dying. Its also backfiring when its reved and just feels like it has no power. I just bought the car so i dont know much about them yet but the only thing done to it is full monza exhaust, oh btw it gave code 55 when i checked the ecu. |
welcome to the site
please use the search function before asking a question. many topics, such as this one, have been covered many times before do this first http://www.ttzd.com/tech/diagnostictech.html and the go thru this thread. it has tons of helpful information on the 2nd page. https://www.zdriver.com/forums/showt...=lost+of+power |
Learn some punctuation too.
Hey i posted for some insight on my problem not dickhead comments
Ive tied forums, ive read through em all, i got a code 55 , ive checked everything i can think of and still cant come up with whats wrong |
we have said nothing out of the ordinary for a new z owner.
tell us what you have tried, any maybe we can help you more. i doubt you have tried everything |
Raisan... They're not "Dickhead Comments"... It rules you have to follow to get ANY respect on this site. I learned quick, you should try to do the same. Don't Swear, use correct punctuation,(this isn't a text message, so none of that crap) and don't try to be a smart@$$ with the guys that you're trying to get help from.
Now, SEARCH... The problem has been talked about alot. Just limit your search to Z32 and use the same key words you're giving us now. We're all here to help, but we shouldn't have to type the same thing 10 times. Oh, Welcome to the site. There's alot of information here for you... just learn how to find it. |
When did schools stop teaching grammar and when did parents stop teaching manners? Calling CC a dickhead won't get you anything more than banned on this forum. Change your attitude or find a new forum.
Ive tied forums, ive read through em all, i got a code 55 , ive checked everything i can think of and still cant come up with whats wrong soo... you didn't click on his link then did you? ECU LED codes for MODE II: 11: crank angle sensor circuit 12*: air flow meter circuit 13*: engine coolant temp. sensor circuit 14*: vehicle speed sensor circuit 21: ignition signal circuit 26*: boost pressure sensor 31*: ECU 32*: EGR function 33*: exhaust gas sensor circuit (left) 34: detonation sensor circuit 35*: exhaust gas temp. sensor circuit 42: fuel temp. sensor circuit 43*: throttle position sensor circuit 45*: injector leak 51*: injector circuit 53*: exhaust gas sensor circuit (right) 54: signal circuit from A/T control to ECU 55: NO malfunctions in the above |
I just posted what you posted on the ECU codes and their meanings. It looked like he still didn't read what you had posted when he mentioned again that he's getting a code 55.
I guess might as well as the 280ZX question for this problem.... Did you wash your engine bay recently? If so you might have some water in your connections there...(don't know if that works for 300ZX's) |
cars running that rough usually dont toss a all good code on the ECU. sounds like a major sensor failur and its in safe mode, or cant run right with out it.
my 3000GT friend is always all paranoid about the ECU failure that they suffer because of something leaking down onto the board in the ECU. I'm looking into the possibility that this could happen in our 300zx's. it causes false readings and false outputs. (not that i would dare degrade a 300 to the lowness of a 3000... no offense...)
Welcome, Raisanbran! We're sorry if you were offended by the previous comments, but proper punctuation and grammar really does help us in trying to read and understand the problem so that we can help more efficiently.
I would have to agree with Snowie on regarding the Code 55. Would you please try to run the ECU diagnostics one more time, just to make sure there's no error codes? Sometimes you'll get no error codes if the procedure isn't done properly. Re-running the codes will help save you a lot of time in trying to figure out the problem, and reading our diagnoses of problems that might not even be relevant. :) |
It's probably the fuel system. Pump failure can cause this problem, as well as a bad pressure regulator or dampner. Search and you'll find one of my many writeups on how to diagnose these. (Advanced search terms like "fuel system" by ZLover4Life, you should be able to find it.)
