Window Troubles
Window Troubles
So my driver side window doesn't function properly. The window goes up and down on command, but when it goes as far up as it can it makes a loud ticking/clacking noise. It also doesn't seal perfectly because it seems like it isn't aligned properly. There is a small gap between the window seal rubber and the glass near the side mirror. It seems like the regulator works ok, but something else isn't working right. Any ideas?
