vg30de to 350 chevy conversion?
Old Feb 27, 2010 | 07:06 PM
  #26
GTR's Avatar
GTR
Badass Z Chick
Originally Posted by 300zgearhead
I'm getting a carbureted 350 so it would all be easy but the mounts.
To put a vg30 back in would mean a lot of work trans rebuild, all of the wiring is about shot and needs replaced, so it would probably end up costing me more money! I can get a good 350 motor cheap because of my workplace. so really all that leaves is the mounts which i could figure something out with them.
The reason i'm so against replacing vg30 with vg30 is that, with all of the bullshit the 300zx packs into the engine bay, something wouldn't get assembled correctly.
I'm not trying to be "unique" i saw videos online and it was something that i wanted to do.
Just curious on reading this and all of your other posts, since you haven't mentioned it once...even though others have...have you even considered the transmission and driveshaft part of this? Not to mention mounts and fitment? I'm not saying it can't be done (since obviously it has), like everyone else here hoping you'll reconsider, I'm just hoping you realized the time, money, and fabrication you're fixing to get into.
Old Feb 27, 2010 | 08:53 PM
  #27
ZLover4Life's Avatar
Encyclopedic Knowledge
Originally Posted by jverz
... when it comes to motor swaps if you're asking, "How can I swap motors" or "Can I swap these motors" you're already under qualified.
There it is.
Old Feb 27, 2010 | 11:25 PM
  #28
jverz's Avatar
Oh! I just remembered the analogy I thought of earlier today.
People who do cross-make motor swaps are probably the same people who as kids kept trying to put the square peg in the round hole.
Old Feb 27, 2010 | 11:29 PM
  #29
KasbeKZ's Avatar
Pr0n Addict
spoken word by gypzrose.
i don't think any amount of discouragement will talk this guy out of it. only time and/or experience will make him realize how bad of an idea it is.
Old Feb 28, 2010 | 03:12 PM
  #30
KasbeKZ's Avatar
Pr0n Addict
and, btw, wheels. want those wheels when you give up!
Old Mar 1, 2010 | 07:56 AM
  #31
300zgearhead's Avatar
I'm not asking how to make the swap. I was just asking if someone knew anything about the mounts, and now that i know its custom fabrication the swap probably isnt going to happen. So i'm working on my engine and i'm going to either fix it or just by a used engine.
Old Mar 1, 2010 | 08:04 AM
  #32
KasbeKZ's Avatar
Pr0n Addict
sad );
no wheels!
let us know if you need any help. we'll get you through this.
Old Mar 1, 2010 | 08:36 AM
  #33
Sorry Kas I'm selling my z32 wheels though! 200 obo
Old Mar 1, 2010 | 04:16 PM
  #34
KasbeKZ's Avatar
Pr0n Addict
haha no need for some stock z32 wheels man.
Old Mar 7, 2010 | 12:40 PM
  #35
Has anyone seen a manual for removing heads? i searched but nothing that i was looking for came up. I just want to make sure everything is done right because i'm hoping to have the car back up and running in less than two months. Any help would be great, thanks.
Old Mar 7, 2010 | 09:52 PM
  #36
It's in the service manual. You loosen partway, and then completely... I don't recall if it's inside to outside or vice-versa, though... check your service manual.
Old Mar 8, 2010 | 08:17 AM
  #37
I dont have a service manual. I just dont want to do something that isn't needed to be done to remove the heads. Would removing the cams make it easier to remove the heads, or would it end up being more work having to put everything back together.
Old Mar 8, 2010 | 08:36 AM
  #38
Now you do: http://www.300zx.co.uk/cgi-bin/manual.cgi
And downloadable: http://www.nicoclub.com/FSM/300zx/
Old Mar 8, 2010 | 10:16 PM
  #39
No you don't need to remove the cams to remove the heads... (LOL)
Remove upper plenum, remove lower plenum, unbolt headers, remove timing belt (which requires much of the front end of the motor being disassembled, or you can cut the timing belt since you'll probably be replacing it anyway), remove valve covers, loosen heads appropriately (don't just go removing bolts flat out - you can warp the head that way).
Old Mar 15, 2010 | 07:25 PM
  #40
I've been working on figuring out what i haven't taken off to remove the intake manifold. I have the front lose but there's something still holding it in the back. i cant see anything and I'm just wondering what could still be holding it. This is becoming a big headache because the engine is dirty which limits visibility so i cant see whats going on.
Old Mar 15, 2010 | 08:14 PM
  #41
Probably the EGR tubes attached to the bottom.
Old Mar 16, 2010 | 04:14 AM
  #42
KasbeKZ's Avatar
Pr0n Addict
there are a few hoses on the very very bottom of the plenum sides. they're very hard to see. a couple long and a couple short. once you can work the front of the plenum up a few inches, you can reach their clamps with needle nose pliers.
fyi, if you don't want to mess with this again, all of those lines can be deleted/rerouted while the plenum is off to make life easier.
Old Mar 16, 2010 | 08:30 AM
  #43
It's not the plenum i have that off i'm going for the intake manifold (What the plenum bolts to!).
Old Mar 16, 2010 | 08:51 AM
  #44
KasbeKZ's Avatar
Pr0n Addict
there are two "intake plenums". one is the upper, the big one with two throttle bodies attached, and one is the lower. if you have the front loose i can't think of anything that would be holding it in the back. as i recall it was very easy for me to get off. it was two years ago since i was that deep though.
BlueKitsune
Other Cars
57
Nov 14, 2009 11:34 AM
anlasak
Aug 17, 2006 02:36 PM
i8acobra
Jul 29, 2006 01:27 PM
91zxtt
Other Cars
23
Feb 22, 2005 06:45 PM
Jayis Mcgavin
Apr 29, 2003 10:27 AM
