Using used engine .. Best way to chain the engine?
Old Apr 27, 2010 | 08:07 AM
300zgearhead's Avatar
What is the best way to chain the engine to drop it in? I just bought a used engine with 54000 on it and i don't know what hook the chains on. Would it damage anything to hook up on the plenum? I'm using a cherry picker hoist to drop it in. Any ideas would be great. Thanks
Old Apr 27, 2010 | 01:35 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
There are two common methods - one uses the bolts that go into the sides of the plenum (they originally hold a bracket in place), an alternative is to use a top plenum bolt and one of the top trans bolt holes.
Best method is with the RameyZ engine sling... uses top plenum bolts.
Old Apr 27, 2010 | 04:54 PM
So if i loosen a couple of the plenum bolts could that do something to the gasket?
Old Apr 27, 2010 | 04:58 PM
KasbeKZ's Avatar
Pr0n Addict
nothing that you have to worry about.
Old Apr 27, 2010 | 05:02 PM
No. But make sure you're not trying to lift the engine via loose bolts... THAT could do something.
Old Apr 27, 2010 | 05:09 PM
Didn't you say use a top bolt? how could i use one if it wasn't loose, or do you mean just don't have it too loose?
Old Apr 27, 2010 | 06:14 PM
KasbeKZ's Avatar
Pr0n Addict
you take the bolt out, and tighten it down on a chain link with one or a few good washers.
Old Apr 27, 2010 | 07:28 PM
Yep.
Old May 6, 2010 | 11:45 AM
domsgarage's Avatar
Tough Guy
I just did this last week, my hook up worked pretty well.
On the driver side of the motor I had a singer on the side where the brake booster vacuum line goes into and on the passenger side i had the slinger on top of the plenum towards the back where its kind of just a cap screwed into the plenum behind the balance bar.
I tried the brackets and it wound up snapping off the motor.
I also tried the top plenum bolts but didnt feel safe at all with them.
JPerkins
Sep 19, 2008 02:12 PM
ZMaster
13
Dec 11, 2005 07:49 PM
madness
May 29, 2005 10:56 PM
smokingzcar
Dec 5, 2002 07:57 AM
Z_For_Life
May 10, 2002 06:20 PM
