TT is king
Old Mar 5, 2004 | 10:50 AM
Riz Z Speed's Avatar
Administrative Brown Guy
My N/A does that as well.
My best guess would be because we still have the stock flywheel. All that weight will take some time to slow down. The lighter flywheels not only rev up quicker, they rev down quicker as well.
Old Mar 5, 2004 | 03:39 PM
emo236's Avatar
confuzed member
yea, that is abnormal. Sorry Rizz, nice try on this one. But mine always goes right down to idle speed. There's something wrong with your car. Most likely it's something like a vacuum leak or sometihing thereof. And yes, we can smoke sr20;s quite easily. We can also smoke 911 turbos and panteras. Oh, and the other day I absolutely raped a sport bike. A modded gsx-r. I'll tell you guys about that sometime...pretty funny.
Old Mar 5, 2004 | 05:50 PM
emo236's Avatar
confuzed member
A vacuum leak is simply a leak somewhere in one of your vacuum lines. I would PM 91zxtt about this. He is currently in the process of trying to target a vacuum leak in his car.
Old Mar 5, 2004 | 08:11 PM
Well since he provided the extra information, then I won't say it's a flywheel thing.
Funny how vacuum leaks have so many symptoms and cause so many problems.
Old Mar 6, 2004 | 03:46 AM
Z_WRECKER's Avatar
i am with emo on this one....mine goes straight back to idle, or close to idle speed. I've noticed a bit of a hesitation problem on my Z too. i have to see what that could be. i know Emo had it too. did you ever fix it man?
Old Mar 6, 2004 | 10:24 AM
emo236's Avatar
confuzed member
I think mine's an injector...I'm going to try to get them ohm tested and see how that comes out and then get some money together to either spend the big bucks and upgrade or just replace the bad injector(s) with OEM ones.
Old Mar 7, 2004 | 12:35 PM
emo236's Avatar
confuzed member
You can do a few things. You can rev the motor via the throttle cable and listen for "hissing." A more accurate thing you can do is have it hooked up to a fogger machine at your local shop. It's pretty cheap (under $100) and it'll target it right away. Or you can go through all the vacuum hoses (there's a lot) and tighten them down and examine them thoroughly. Goof luck.
eZdoesit
Jul 28, 2011 06:28 PM
BlueKitsune
Mar 7, 2011 08:41 PM
ViperGTO99
Apr 3, 2009 06:49 PM
maroon300zx
Jan 7, 2005 11:57 PM
91zxtt
68
Dec 21, 2004 10:29 AM
