Timing Belt Replacement???
Old Dec 18, 2005 | 09:57 PM
emo236's Avatar
confuzed member
well, take a look at the timing belt, if it doesn't looked cracked, etc....then it should be ok. change it at 60K....changing it now wouldn't hurt though.
Old Jan 7, 2006 | 11:41 AM
nismo613's Avatar
How bad is it to change the timing belt yourself?
Old Jan 7, 2006 | 01:23 PM
CanyonCarver's Avatar
Jack Of All Trades
I say 7 on a scale of 10. tt.net has the write-up. It's excellent. You need to have a decent set of tools, and patience. You have to remove quite a bit of stuff to get to the timing belt. If you've done any wrenching before, you can do it. Don't try and skimp on the replacement parts. Replace everything that you can while you're in there.
Old Jan 8, 2006 | 12:12 PM
nismo613's Avatar
What else would you suggest i replace?
Old Jan 8, 2006 | 04:37 PM
Jack Of All Trades
I would do everything that comes with the 60k kit plus the upper and lower radiator hoses. I would also replace the vacuum lines and fuel lines that I could easily get to.
COURTESY 60k KIT
imho, no need to do the 120k kit with the idler pulleys since metal doesn't wear when it's not turning.
Old Jan 8, 2006 | 05:11 PM
nismo613's Avatar
Ok, thanks for the info!
Z Pal
Jan 9, 2015 02:35 PM
87z
Sep 13, 2011 01:14 PM
z32convertible
Jan 8, 2011 11:05 PM
Turbo86
Jun 10, 2006 07:12 AM
GWC300ZX
Apr 27, 2003 02:44 PM
