Timing Belt Change / Parts List
Old May 12, 2005 | 06:27 PM
CanyonCarver's Avatar
Jack Of All Trades
It's now that time to change the old timing belt. I've been shopping. Help me out on the attached list with any parts that I might have missed. I plan on changing anything and everything (maintainence wise) that I can get to with the upper plenum off. Are there any other parts that I can get to by removing the lower plenum while I'm in there? I also plan on cleaning out all of the egr tubes and passageways.
Any arguments, for or against my choice of parts? If they're not nissan, they're all name brands like gates, felpro, ntn, skf. Does anybody know the diameter of the by-pass hoses? I'm not buying the nissan hoses because, it appears, that most of them can be cut from straight hose at about $3 per foot.
File Type: doc
Old May 15, 2005 | 04:59 PM
91zxtt's Avatar
If you are going to take off the plenum, then you'll need the upper plenum gasket and the gaskets for the EGR return lines (2).
Old May 15, 2005 | 07:03 PM
b300z's Avatar
caught the z fever
how about your coil pack connectors...are they broken? any other connectors that are down there need to be replaced?
Old May 15, 2005 | 07:07 PM
Jack Of All Trades
Thanks, I was hopin' you'd come thru, It looks like there's only two of us here that work on our carz.
I just finished up putting in a new clutch in the kids '01 civic. Took like 11 hours. It's the first time I've been that deep into the driveline of a fwd car.
There are no broken connectors that I can see. Gauranteed that I'll break a couple along the way. I have the dielectric grease that I'll be adding to each connector as it's cleaned at re-install.
Old May 15, 2005 | 07:34 PM
Zgringo's Avatar
El Viejo
CC the only difference in your parts list and mine is the timing belt, but I see no problems. My findings is most after market people make there parts as good or better than OEM. (excluding cut rate parts)
I don't know what the big fuss is about changing the Tbelt. Just make sure the tensioner is done right and I see no problem, just takes time.
Years ago when I did my first one I followed the steps outlined in someones website in Texas and it worked out fine and now I just do it.
Have fun.
Old May 15, 2005 | 07:37 PM
b300z's Avatar
caught the z fever
hey...i work on my car too...just not that deep yet
how about your iacv or aru? do you have any idle or hesitation? you might want to check the voltages on those while they are off
Old May 15, 2005 | 07:49 PM
Zgringo's Avatar
El Viejo
Good point to bring up.
By the way b300z, I sure like your Z.
Old May 15, 2005 | 08:01 PM
Jack Of All Trades
I know........... That was my point. A timing belt is a big job. There's a lot to mess up in there.
No hesitation or stumble what so ever. I have been noticing the idle dropping to around 400-500 rpm when approaching stops, before it settles at 750 rpm. The iacv will be cleaned.
What's a aru?
Old May 15, 2005 | 08:52 PM
Riz Z Speed's Avatar
Administrative Brown Guy
hey, i work on my car.
just nothing is really wrong with it right now.
Old May 15, 2005 | 09:19 PM
bardabe's Avatar
Bad Speller
so Y do you say it isn;t driveable??
Old May 16, 2005 | 06:09 AM
Jack Of All Trades
wooooohhhh, how do you guys say that?????????? PWNT j/k rizz.
Old May 16, 2005 | 11:17 AM
b300z's Avatar
caught the z fever
yeah, i remember you saying something about a new hood, and a bunch of other crap...too bad i cant find it
aru=air regulatory unit...if you follow the big iacv hose around the backside, its connected to the aru
Old May 16, 2005 | 12:57 PM
i didn't say it wasn't driveable.
just some minor bodywork is needed.
car is still mechanically sound.
Rrassi300zx
Mar 20, 2013 04:44 PM
Frodz
Jan 1, 2012 09:04 AM
OutlawZ
Aug 10, 2011 07:28 AM
Tonyw
Aug 19, 2009 10:57 PM
rngrck
May 1, 2002 12:31 PM
