Tapping Noise Front Left Cam Sprocket Area
Old Jul 12, 2005 | 10:16 PM
bardabe's Avatar
Bad Speller
do the 120K mile maintenace on it. or it coudl be that it needs an oil change or the Oil is too thin.
Old Jul 12, 2005 | 11:03 PM
Riz Z Speed's Avatar
Administrative Brown Guy
check to make sure the timing chain is not damaged and "slapping" against the cover.
Old Jul 13, 2005 | 05:55 AM
CanyonCarver's Avatar
Jack Of All Trades
Factually speaking........ The tapping could be a sticking lifter, noisy injector, or maybe the timing belt broke on the previous owner and one of the valves got slightly bent.
You can take a long screwdriver and put one end on various parts of the engine and put your ear to the other end and listen around to narrow down where the noise is coming from.
If it runs o.k., it's prolly not a bent valve because that will usually cause a compression leak in the given cylinder. If it's a sticking lifter, you can try running some marvel mystery oil in the motor and then change the oil. Some people use ATF. This is known to clean things up inside and eliminate some of the noise. On the noisy injectors, well they can be noisy.
El_Colombiano
May 1, 2013 07:12 AM
MylesBlaq
Feb 7, 2008 04:40 PM
Comrade_Charlie
Jun 28, 2006 09:42 AM
Zpeed
Aug 12, 2002 07:50 AM
Zpeed
Jun 22, 2002 10:06 AM
