Synthetic in my Z?
Old 04-19-2004, 06:06 PM
Turbo Fanatic
Tuuurbo's Avatar
Synthetic in my Z?
I need to get an oil change done and i was wondering if I should start putting sythetic in it? I talked to nissan and they said they dont recommend it. But I want a second opinion...Its a 94 non-turbo engine. I know in my old 280ZXT, i stuck with regular oil and it always ran fine. Thanks
Tuuurbo is offline
Old 04-19-2004, 07:04 PM
JAMESZ's Avatar
How amny miles are on the engine?
JAMESZ is offline
Old 04-19-2004, 09:16 PM
91zxtt's Avatar
I switched to synthetic. Mobil 1 15/50. Probably the best oil around. You can switch at any time. Miles don't really matter. For a long time, people said that if you switch to synthetic in a high mile engine that the synthetic oil can penetrate the seals and cause oil leaks. There have been studies that support both sides of that argument. The synthetic does provide better protection. What you want to ask yourself is this....Do you care if there's a small spot of oil on your driveway? It's been 80k since I switched, and my car leaks very little. I'm happy with it. It's up to you.
91zxtt is offline
Old 04-20-2004, 12:52 PM
Administrative Brown Guy
Riz Z Speed's Avatar
Agreed.
I've heard both, It leaks, it doesn't leak.
So all you can do is try. The more expensive Mobil 1 is worth it.
I switched, no leaks. Mine's older with more miles too.
Riz Z Speed is offline
Old 04-27-2004, 04:33 PM
Tough Guy
domsgarage's Avatar
I Switched to Castrol Synthetic Blend. Car runs fine, doesnt leak.
domsgarage is offline
Switchtr3
03-06-2012 11:42 AM
KasbeKZ
05-24-2010 08:21 AM
arsey51
05-11-2009 03:50 PM
pearly whites
05-13-2004 12:03 PM
Wolfe
12-01-2001 11:40 PM
Quick Reply: Synthetic in my Z?
