Starts but cant hold idle
Old Apr 7, 2010 | 11:45 PM
Lanoi's Avatar
Well cam seals are in and no leaky oil. now i can start the car but it cant idle.
when i start it up, it starts fine. trys to idle for a brief second or two, and the rpms gos down to the point which it stalls. I have check for disconnected or crack vaccum lines. TPU, i think it may be the MAF not sure. i dont have a spare one to try out. any advice about MAF or other things i may have looked over.
Old Apr 7, 2010 | 11:58 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Sounds like a massive air leak (not a small vacuum hose leak)... check your intake pipes to make sure they are all on properly.
MAFs don't generally go bad for no reason. Also check the connectors on the rear driver's side of the plenum (one is the IACV).
Old Apr 8, 2010 | 12:24 AM
Lanoi's Avatar
idle air control valve i try adjusting thwe screw in and i pretty much did the same thing but when the rpms go down low to where it should stall it jumps up then stalls
Old Apr 8, 2010 | 12:34 AM
How low do you think it's supposed to go? Z32s should idle around 800rpm. (And generally, you shouldn't mess with that until it's running healthily... you may have just added to the problems later on.)
Old Apr 8, 2010 | 12:44 AM
Lanoi's Avatar
i was thinkng around 750 range up or down a bit . massive air leak huh .
Old Apr 8, 2010 | 12:45 AM
Lanoi's Avatar
i dont hear much of anything like air noises
Old Apr 8, 2010 | 12:52 AM
Spec is actually 750 to 850, but I generally aim for closer to 850 so it's a little smoother.
... and of course you can't hear air leaks, the car is dying. lol
Check all your electrical connections to be thorough.
I don't recall, are we talking TT or NA?
Old Apr 8, 2010 | 01:11 AM
Lanoi's Avatar
i have n/a
Old Apr 8, 2010 | 08:00 AM
KasbeKZ's Avatar
Pr0n Addict
it could be a fuel pressure problem. hook a gauge up, look for a drop after it primes, pinch the return line ext. that'll let you know if it's a fuel problem.
as for the maf.. just unplug it. if the problem persists, it's not the maf.
Old Apr 8, 2010 | 02:10 PM
Lanoi's Avatar
its the MAF i just clean it out and car runs and idles now
Old Apr 8, 2010 | 02:14 PM
KasbeKZ's Avatar
Pr0n Addict
wow... that goes against so many threads that i've read saying that the maf doesn't affect idle.
Old Apr 9, 2010 | 10:53 AM
Lanoi's Avatar
yea most the treads ive read say vaccum hose or AIC , but it was easy to clean with the MAF cleaner from a bottle took like 5-10 mins.
spaceviolence
Apr 8, 2014 04:23 PM
originalzboy
Feb 8, 2014 09:46 AM
renny
Sep 16, 2010 08:36 AM
CraigS
Aug 25, 2007 02:57 PM
Petezcar
Jan 21, 2002 02:40 PM
