Short Shifter
Old Dec 20, 2004 | 05:22 PM
Lucky91647's Avatar
From: Currently: San Diego, CA; Originally: Redding, CA
Short Shifter
I'm on ebay. Great site. I see advertised short shifters. They look pretty bare bones. Are there any linkages or connectors or anything else you need for these to work? I've been told there are in other cars and I should make sure about this before buying. Also, how do you change the little blurb under your user name? I don't want to be Registered User anymore. :headspin:
Old Dec 20, 2004 | 05:33 PM
Lucky91647's Avatar
Case in point:
http://cgi.ebay.com/ebaymotors/ws/eB...942437055&rd=1
Old Dec 20, 2004 | 05:58 PM
lightspeed's Avatar
Southern Speedster
That looks pretty complete. Here's the kit at Z1.
http://z1motorsports.com/product_inf...roducts_id=132
You may want to consider replacing the bushing that goes through the round ball end, though. My was slightly worn and after I added the SSK, mine buzzed until I replace that bushing. You can nomally use the Nissan busing with is only a buck or two. I believe it will replace the two smaller pieces of plastic shown.
Now you will have a surprise in store for you if you haven't done one of these on a Z32. You may want to do some research on the process. You have to be a contortionist if you do it from the top, not to mention that you have to remove much of the center console.
If you want to drop the h-pipe and the drive shaft, it is much easier if you have bottom access, plus you can tighten the lower bolt much easier.
Others may have some opinion regarding the all aluminum version...
Old Dec 20, 2004 | 06:07 PM
Lucky91647's Avatar
Thanks, just what I was asking for.
Old Dec 20, 2004 | 08:28 PM
91zxtt's Avatar
Courtesy Parts sells one also. That's what I have. It comes with the bushings. You can still use the OEM gearshift with it also. I actually think that the quality of it surpassed that of the OEM unit.
Old Dec 21, 2004 | 11:23 AM
Lucky91647's Avatar
I have an aftermarket Razo CF shift **** anyhow. I'll look it up though. You know how much?
Old Dec 21, 2004 | 01:05 PM
91zxtt's Avatar
I'm thinking it was $150ish.
Old Mar 21, 2005 | 07:12 PM
waterdogzx's Avatar
Upstate Z Moderator
I'm convinced the $40-$60 short shifter on ebay is the same as the $150 one on Z1 and Courtesyparts. I bought the ebay one and it looks identical to the pictures on both the Z1 and Courtesyparts websites.
Help me out with all this talk about the bushings. The shifter came with plastic or nylon bushings. Are you saying that the stock bushings from Nissan are better? Should I use stock replacement bushings instead of the nylon ones that come with the short shifter?
I have to have all my parts ready before I take my console apart. I have to drive my car so I can't wait and order bushings half way through the job.
Old Mar 21, 2005 | 07:37 PM
waterdogzx's Avatar
Upstate Z Moderator
Also, I found a write up on how to replace the bushings on twinturbo.net. Are these instructions pretty much all I need to follow to install the short throw shifter?
Anybody know of a good (complete) writeup on this?
Thanks...
Old Mar 22, 2005 | 06:03 AM
Woody75(Denver)'s Avatar
Should have bought one of mine instead. Ebay ones are junk. You'll get what you paid for. Be prepared for rattles and bad shifter bushings. And some extra vibration.
Old Mar 22, 2005 | 02:37 PM
lightspeed's Avatar
Southern Speedster
Thanks...
There are a number of write ups that help you replace it from the top. You WILL bang up your knuckles. If you have time and a lift, you can get to it much easier from the bottom, but you will have to remove the h-pipe and the drive shaft.
Old Mar 25, 2005 | 04:34 PM
turtleboy's Avatar
turtled user
2nd... Woody or SilverTwin or buussst.
I think they are both 50 bucks. F ebay.
Old Mar 27, 2005 | 09:43 PM
nka04a's Avatar
Thanks...
I found a good write up...... http://www.zchickz.com/z32-shift1.htm
WanganDevilZ
Jan 6, 2010 09:59 PM
ern
Jun 22, 2006 08:51 AM
hogboy36
24
Nov 4, 2005 08:04 AM
nka04a
Mar 15, 2005 07:02 AM
highwaystar
Jan 26, 2005 01:55 PM
