Running on 5
Old Apr 27, 2006 | 06:02 AM
beez's Avatar
Running on 5
Hi,
I have been trying to fix a problem with my Z running on 5 and was hoping anyone would have any recommendations on what to look at?
Firstly the plugs have been changed and the PTU was cleaned as it had some corrosion on it and this seemed to fix the running on 5 problem but only for a very short period.
Also about a day or so ago I noticed the injector warning light has come on.This is the first time this has ever happened and did not accur from the very beginning of when the car started running on 5.
The car seems to always fire on 5 when cold but sometimes and rarely when warm the car fires on all 6.
So if anyone can possibly give some common problems that may be causing the above issue i'd greatly appreciate it.
Beez
Old Apr 27, 2006 | 06:49 AM
Z'sOwnTheRoad's Avatar
I would check to make sure all your injectors have b/t 11 and 13 ohms of impedance, that is my first guess due to the fact i have had injector problemsvery similar to yours.
Old Apr 30, 2006 | 01:17 AM
bLackout's Avatar
had the same problem
have a 91 TT that started firing on only 5 cylinders. made sure all the injector wires are secured to the injectors...juss make sure ur injector wires are not loose.
WildmaN
Feb 25, 2007 08:57 PM
WildmaN
Nov 27, 2006 08:49 AM
EZDUZIT
Jul 5, 2006 02:03 PM
Nemesis280zx
Jun 29, 2006 02:57 PM
Soup80
Dec 14, 2003 01:53 AM
