Roiugh at low RPMs
Old Aug 5, 2006 | 05:38 PM
KevinH's Avatar
Roiugh at low RPMs
My '93 N/A is suddenly running rough below 2500 RPM. I cleaned the throttle bodies with no change. I sprayed about 1/2 a can of carb cleaner into line that goes to the AAIC (sp?) valve too (one on the back of the driverside block). Realize, that this was like an overnight change, which I don't understand. I have gotten a chance to check the computer code(s) yet. I have re-set the computer and it did it once again. Looking for ideas - Thanks!
Old Aug 5, 2006 | 07:10 PM
b300z's Avatar
caught the z fever
did you search? there are many threads about problems like this...
read thru this thread, and go thru the attached linkshere .
carb cleaner is not a good thing to put in a Z
Old Aug 6, 2006 | 03:32 PM
Aphrodite's Avatar
just a thought... check the wires going to and coming from the PTU, I had a similar problem and had one wire shorted to another because they had been rubbing on a belt.
Old Aug 15, 2006 | 06:25 AM
KevinH's Avatar
Yeah I did a search! Your thread didn't do me any good either. And what do you think throttle body cleaner is? Its the same as carb cleaner!
I did find my issue. I went to twinturbo.net and found what I needed.
Old Aug 15, 2006 | 08:29 AM
b300z's Avatar
caught the z fever
carb cleaner is not the same as throttle body cleaner. throttle body cleaner is made to be used on EFI cars because some throttle bodies have a permanent lubricant, which carb cleaner will remove. i bought a can of carb cleaner a while ago, and i believe it said on it not to use on EFI vehicles...
what was the culprit, btw
Old Aug 15, 2006 | 09:50 AM
yeah what was the culprit, cuase now that my car shat on me looks like the other N/A 300's are following in suite.
77280ZX
Nov 7, 2012 03:36 PM
JCastro2866
Feb 2, 2012 01:00 PM
ramjv
Sep 9, 2010 11:23 PM
wake2wake
Nov 7, 2006 04:07 PM
elementsofway
Jun 2, 2006 09:29 PM
