Unwanted RPMs
Old May 3, 2006 | 09:05 PM
elementsofway's Avatar
Unwanted RPMs
Car: 1978 280z
When starting, the car idles properly at about 800 rpms; however, if I wait a few seconds the car's idle will increase to about 2500 rpms. What sensor would cause this? If not a sensor, what else could be the culprit?
I should also note that while driving the car, the car will idle between 2500 and 2700 rpms. In gear the rpms will go as low as 1200 but I haven't fully tested to see how low the rpms will go.
Thanks
Old May 4, 2006 | 07:29 AM
naviathan's Avatar
Could a number of things, but my first guess is going to be a vacuum leak at the manifold. Then I would guess the BCDD (Boost Controlled Deceleration Device, it's located under the throttle body). Testing the BCDD is easy, just pull the vacuum line off it and plug it up. Vacuum leaks, use a can of carb cleaner or a propane tank and spray around the intake and vac lines until the idle changes.
Old May 4, 2006 | 01:32 PM
TEDS280Z's Avatar
Same thing
My '77 280 was doing the same thing. Now that I've had the whole thing rebuilt (have'nt installed it yet) I'm not sure. One thing I found out to be it also could be the cold start timeswitch. I bought a new on from autopartswharehouse.com. Lowest price I could find.
Old May 4, 2006 | 04:18 PM
try the tps or your timing seems to make it go away. weird, but thats what mine was doing.
Old May 25, 2006 | 03:02 PM
Thanks for the quick response. It ended up being both the boost controller and the water temperature sensor. Now the engine sounds perfect. Thanks.
Old Jun 2, 2006 | 09:29 PM
myxtaz's Avatar
Car show and shine
THERE IS A SHOW AND SWAP MEET ON 6/10/ AND 6/11 IN CANBY OREGON THERE WILL BE CARS THERE FROM CANADA IDAO WASHINGTON AND OREGON.
77280ZX
Nov 7, 2012 03:36 PM
JCastro2866
Feb 2, 2012 01:00 PM
ramjv
Sep 9, 2010 11:23 PM
wake2wake
Nov 7, 2006 04:07 PM
KevinH
Aug 15, 2006 09:50 AM
