powering up the ecu
powering up the ecu
i,m putting a vg30dett in a z31. I have the engine and trans mounted and now on to the wiring. Ive identified the wires but not sure which power source wires get full time 12v or what
has anybody on this forum attempted to put a vg30dett in a z31? I saw it on youtube, wiring seems it's going to be the biggest problem, fabbing and fitting and making isn't to bad, you know how it goes there's not a fuel pump wire from one to the other, there's a fuel pump and a fuel pump relay on the z31 and just a fuel pump control on the dett
You could always search.
I know you will get plenty of results by searching for VG30DETT in the Z31 section... we had a huge discussion about it a week or two ago. It's not a common swap because it's not very realistic.
EDIT... unfortunately there isn't too much info on a swap (you might try Hybridz.org for more info) but since you are in the process, it would be very awesome to have you do a write up for this site.
I know you will get plenty of results by searching for VG30DETT in the Z31 section... we had a huge discussion about it a week or two ago. It's not a common swap because it's not very realistic.EDIT... unfortunately there isn't too much info on a swap (you might try Hybridz.org for more info) but since you are in the process, it would be very awesome to have you do a write up for this site.
