O2 sensors
Old Jan 14, 2005 | 11:27 AM
tt300z's Avatar
O2 sensors
How hard is it to change them because i cant even see them..i can feel them but only barely see them...anyone have any special ways that i am not figuring out..or am i just letting the car be more smarterer than I?
Old Jan 14, 2005 | 05:24 PM
lightspeed's Avatar
Southern Speedster
most recommend a O2 tool available at your local parts store for about $10-12. The passenger side is more accessible if you remove the battery. Practice calisthentics for the driver side. Many find it necessary to use a rachet with a couple of swivel joints to accomplish the job.
(Then there are those of us with an additional 2 after the cats (OBD II). And that's a different story totally.)
Old Jan 14, 2005 | 10:25 PM
Riz Z Speed's Avatar
Administrative Brown Guy
whatever you do, just be sure to get that special sensor removal wrench.
Old Jan 15, 2005 | 06:07 AM
tt300z's Avatar
why is that?
Old Jan 15, 2005 | 08:57 PM
WhtFairLadyZ's Avatar
O2 Wrecnches are basically pipe wrecchs..all the do is keep you from stipping the bolts. The tool lightspeed is referring to looks like a deep well socket, with a section cut out on the side like an arch way of a door. This cut out is so that you dont mess the wires up on the O2 sensor. If you dont understand what I mean, you will once u get the tool. It will make life much easier.
Old Jan 16, 2005 | 09:43 PM
91zxtt's Avatar
If you haven;t done it already, removing the battery and the master cylinder make it much easier also.
zordietrying
Dec 21, 2012 01:30 PM
drummer69
May 30, 2006 07:33 PM
81 Black L28E
Oct 6, 2005 06:54 PM
Brewster
May 1, 2005 10:05 PM
tenjin
Apr 19, 2003 09:43 AM
