Noise coming from dome light
Old Sep 15, 2003 | 03:09 PM
lifegrddude's Avatar
Externally Wastegated
Not sure about the dome light noise, but it may be coming from your engine bay due to a loose fan belt. Pop the hood and check it out while a friend revs the motor a bit. Other than that, I don't know what else to say. Maybe a bad ground somewhere like when speakers make that whining noise?
John 82ZXT
Old Sep 16, 2003 | 09:58 PM
I don't own a 300 like you do, but if it's that fan that's making the noise, maybe it needs to be lubed. Check with a Haynes or Chiltons manual on how to access it to see if that's all it needs.
John 82ZXT
Old Sep 17, 2003 | 10:43 PM
300zxBoi's Avatar
I had the very same problem. And it was the fan in the light that calculates the climate of the car. I Poped the light off and i took out the fan. You can try your best to lube it or whatever but it doesent hurt to stick somethin in there so the fan doesent rotate.
Old Sep 20, 2003 | 12:31 PM
maxp's Avatar
http://www.twinturbo.net/ttnetfaq/FAQpages/tempfan.html
http://www.aus300zxclub.com/tech/acfan.htm
Old Sep 22, 2003 | 05:58 AM
tsefreeflow's Avatar
I'm Chillin
You cannot get a Haynes or Chilton manual for the Z32s, they were never made. You can get a manual on CD thought off of ebay or Courtesy-Nissan.
jti30666
May 21, 2012 02:18 PM
SoulAmazing
May 18, 2011 01:41 PM
njgheewala
Jun 17, 2009 10:56 AM
GeeYawn 280zx
Jan 25, 2004 05:51 PM
1tuffz
Sep 15, 2001 04:10 AM
