No spark at all :(
No spark at all :(
Hi, It's great to join the club. To start everything off... I have a huge problem. I am not getting spark in one cylinder, I have changed coil pack,injector,ptu,plugs,and connectors but still no fire from just that one coil. I have tested all the coil wiring and it comes up the same voltage of 14.6V on every plug... every one including the one that doesn't work.
I can piggy back it off the coil next to it and it fires but runs bad of course because they are firing at the same time.
The center wire is the one that I piggy backed off so it must be something to do with the center wire. What does that wire do?
Does the ecu send a pulse to each coil? Or is there a chance it may be the ecu?
Could the CAS have something to do with this?
WHAT'S WRONG???
WHAT'S WRONG???
The CAS sends the cam position signal to the ECU, which (I believe - it's been a while since I dealt with the system) sends a signal to the PTU to distribute the spark to the separate cylinders. I'll think about this for a while and let you know if I have any ideas, but I don't suspect it's your CAS. It's probably a broken wire somewhere.
Fairladyz1990AF
04-24-2014 04:15 PM
