no spark please help
Old Dec 3, 2005 | 02:59 PM
Boosted Z's Avatar
Banned
hi i puting my motor back together and i tryed starting ti it started for a second realy rough i was checking to making sure the harrnesses where in the right spot i think the right side o2 sensor plug and that coil pack plug i got mixed up i took the coil pack out(number 1) and put a plug in and i took crank angle senor out and spun the wheel to see if it sparked and ikt didnt what would this be that would cause it not to spark?
Old Dec 3, 2005 | 03:40 PM
91zxtt's Avatar
It's really difficult to figure out what you're trying to say. Try using some commas and a few periods here and there. The coil packs are 3 wire plugs whereas the O2 sensors are 2 wire plugs, so you likely didn't mix those up. If you are re-using the old harness, I'm assuming you didn't label everything before you took it apart? If so, then that'll make it a bit more difficult.
I believe that the ignition needs to be on to conduct the test you tried. Was the ignition on? How are you checking for spark i.e., what are you using to determine whether or not there's a spark?
Old Dec 3, 2005 | 03:57 PM
Boosted Z's Avatar
Banned
ok what i did was take out crank angle sensor and took out coil pack
1,then followed by puting a spark plug in the end of coil pack, then
grounded the spark plug and spun the crank angel sensor spindle, then
what i did is tryed every coil pack wire with the same coil pack that i took
out, so my next guess was the transitor pack harness being dirty any
part of it, so i cleaned all the harnessses everything was working before
so i feel everything is good,unless something shorted, but how would i
check? i dont no what to do this my first time taking a fuel injection motor
apart so its a bit differnt ovously and my O2 senor i thought had 3 wires
a white,red,black with that fire sleeve on it, it was the coil pack on the
back right that i got mixed up, so i looked at manual the exhuest sensor
said it was the harness with black white and black.blue
Old Dec 3, 2005 | 04:05 PM
CanyonCarver's Avatar
Jack Of All Trades
You didn't answer his question........ did you have the battery connected and the ignition key in the "on" position when you tried the spark test?
Old Dec 3, 2005 | 04:07 PM
Boosted Z's Avatar
Banned
yes and the injectors cliked also
Old Dec 3, 2005 | 04:13 PM
91zxtt's Avatar
Grounding a spark plug in the daylight can be very difficult to see. If I were you, I'd put everything together and let her rip.
You do have the PTU connected, right? Make sure you clean those connections very well. They have a tendency to be problematic. That could be why you're not getting spark.
Old Dec 3, 2005 | 04:15 PM
Boosted Z's Avatar
Banned
what a ptu? i did i sat i tryedstarting it for hours playing with it i got confused also with dentnation sensor harness and vtc gears ,there both 2 wire,i tryed switching th harnesses annd reseting the comp i dont no no what to do
Old Dec 3, 2005 | 06:53 PM
emo236's Avatar
confuzed member
PTU=power transistor unit. It should be on the front timing cover on the left side. Or if it's been relocated, it's most likely next to the intake. It looks like either a silver box with a heat sink on it or a black plastic large connector. Teh heat sink one is recalled adn it needs to be replaced.
Old Dec 3, 2005 | 09:41 PM
Boosted Z's Avatar
Banned
why would the ptu go bad if my car ran before i took it apart so change the ptu how bout the coil packs? are there anything else that is apart of ignition system besides spark plugs,coil packs,and PTU?
Old Dec 4, 2005 | 07:10 AM
Boosted Z's Avatar
Banned
well i have the plastic one so i ges thats not a recall ,so how can i test the ptu to see if its doing what its saposed to,the motor started once but it was making wierd noises and it was realy rough could that have messed the motor up i dont have moeny to pay people to fix it so i took a shot at playing with the motor,iv always fix my trans and flyy wheel all the other sdtuff but i never took the ppleum off before, so i ges its time to learn how to make it work again but i want to fix it so i dont have to pay any one , so what else could make the engine get no spark? i tested the coil packs with ohm meter they all read the same( asuming that means there good)
Old Dec 4, 2005 | 08:13 AM
Boosted Z's Avatar
Banned
i tested the ptu for continuity nothing at all so im replacing it, ehat is the firing order of the pistons front front left to back then right side front to back?
Old Dec 4, 2005 | 06:53 PM
91zxtt's Avatar
Don't just randomly change you're connections. Find out what is the knock sensor, VTC, O2 etc. and plug it into the right place. Don't half *** it because you'll f*ck something up if you haven't already.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
1985nissan300zx
Oct 8, 2011 10:20 PM
Beseke
Jul 26, 2005 11:16 AM
z4doug
May 21, 2005 05:43 PM
