No spark at all :(
Old Apr 15, 2010 | 11:32 PM
Thenumber1z's Avatar
No spark at all :(
Hi, It's great to join the club. To start everything off... I have a huge problem. I am not getting spark in one cylinder, I have changed coil pack,injector,ptu,plugs,and connectors but still no fire from just that one coil. I have tested all the coil wiring and it comes up the same voltage of 14.6V on every plug... every one including the one that doesn't work.
I can piggy back it off the coil next to it and it fires but runs bad of course because they are firing at the same time.
The center wire is the one that I piggy backed off so it must be something to do with the center wire. What does that wire do?
Does the ecu send a pulse to each coil? Or is there a chance it may be the ecu?
Could the CAS have something to do with this?
WHAT'S WRONG???
Old Apr 16, 2010 | 10:29 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
The CAS sends the cam position signal to the ECU, which (I believe - it's been a while since I dealt with the system) sends a signal to the PTU to distribute the spark to the separate cylinders. I'll think about this for a while and let you know if I have any ideas, but I don't suspect it's your CAS. It's probably a broken wire somewhere.
Old Apr 16, 2010 | 12:01 PM
KasbeKZ's Avatar
Pr0n Addict
this is depressing. you're getting rusty. you need a Z32!
Old Apr 17, 2010 | 10:03 AM
You're absolutely right... I do. But for now, I'm going out to the garage to paint my 240Z and then replace some **** on it without breaking knuckles and cutting myself.
Old Apr 17, 2010 | 04:29 PM
Lanoi's Avatar
u tested the voltage on the connector of the coil right. u ohm the coil pack u tryed ?
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
Boosted Z
Dec 4, 2005 06:53 PM
Beseke
Jul 26, 2005 11:16 AM
z4doug
May 21, 2005 05:43 PM
