my car wont start
my car wont start
my car wont start i checked for spark, fuel presure,CAS,i have a new PTU, and it wants to start but it doesnt it fires ever few cransk or so i cant figure why it wont work im pissed off some one help please
Maybe it's your hydro power.
Check your flux capacitor, halogen fluid, muffler bearings and homogenizer.
You probably have something wrong with the wiring since you didn't label it before removing it all. Check the FSM for a wiring diagram that tells you which electrical plugs go to which tabs at the ECU side of the EFI harness. Grab your OHM meter....happy hunting.
dont you need a left handed crescent wrench to fix that?
Go look at which direction you move your thumb to close a normal adjustable wrench. Mine is opposite.
I'm still looking for a left handed coffee cup. ie: look a which side of a coffee cup the picture, or saying, is on when you hold it in your right hand. I haven't seen one for lefties.
Oh, YEAH, you won't believe how many times I've designed $**** that works perfect for me, but I have to redesign it and remake it for the retarded right handed people that can't adapt to the left handed man's world..... Geez, get a clue.
/rant
soldered new ones on it perrs now, but cylender#6 isnt i dont no why, it
looks like its firing after looking at hte plug it wasnt fuel soaked or fouled
but i changed the coil pack and still nothing when i pull the wire off the
coil pack ,i even changed that coil wire, still nothing dont no wat else it
could be the injector is clicking i was listen to it with a screwdriver, i have
no idea why that one cylender doesnt drop in rpms when i pull the wire
Check the resistance on the injector. Also check the connection at the injector. You could have the same problem as what you had with the other connections.
those are low numbers.......i was having a simmilar problem with one of my cylinders its not firing at idle really but kicks in after 2500 rpm...at one point it didtn work at all but i cleaned out the computer adn stuff under the floor board replaced the coild pack got it working...and i thik i need to replace those plugs cuase another cylinder stopped working last night and pushed on the plug wire and got it going again.....those coil packs can be retards i tell yah...but yeah it still sounds like a miss at idle...its wierd dotn know y..i should probly get around to compression testing but i hardly get free time
moorebl
Apr 14, 2011 03:28 PM
