my build check it out
Hello every one! Im here to share my exsperiants how ever u spell that. with my z. i want to let every one enjoy my car as much as i do.
im gonig to start off with my list of mods
ENGINE
ENGINE
- carillo super a beam rods
- wisco pistons
- stage 4 head with stage 3 parts from z1
- 675rs turbo kit
- nx direct port nitrous kit with boost progresive control used for spool up shot and safety of direct port
- UR pulleys
- RPS clutch and fly wheel
- ss brake and clutch line
- chromoly pivit ball
- 97 spec tranny
- arp head and mains
- labree 3 inch super split pipes
- 3 inch custom exquast system
- Z1 oil cooler
- howe radiator with spal fan
- AEM stand alone with knock sensor
- PLX R 500 wide ban with egt and knock and g sensor
- apexi boost controller
- greddy turbo timer
- greddy intercoolers
- on the way is masive ash and 2.5 pipes
- cometic head gasket
- greddy timing belt
- new oil pump water pump and gasket kit
- coated oem bearing
- if i have forgoten somthing i will post it later forgive me
- mike smith manifolds
- 2 way carbon diff by carbonetics
- all t bolts clamps on everything
- tt fuel pump
- aeromotive fpr
- 850 cc injectors
- upgrade plenums
- custom lovours behind the wheels for better flow for intercooler along with ducts front my fog lights to help with heat soak
- wings west body kit
- seamless design done by me
- veilside ec2 wing
- removed rear wiper and ant. and side lites
- volk sf chalenge rims on order
- colbolt blue kandy paint job soon
- no new intior yet but soon hopfully
- stillen bars and spl end links
- tien coilovers
- front and rear upper control arms
- traction arm
- toe arms
- all new ES bushings
- solid subframe bushings
- spl front fender braces
- roll cage on the way
Ok so let me tell you guys about my ride. it was orginally a N/A. its a 2+2.
I started out with the howe rad and spal fan, But i bought it for turbo model because i knew I would be doing a swap later when i got all my parts. then i bought new trans and rps flywheel and clutch,Then Ur pulleys, I did brake upgrades first. followed by suspension. Then i did the power plant I wanted to handle the power and be able to stop. Also i got roturas on order for aditional stoping power.i cant upload the pictures at the molent some troubles are acuring so please be patiant thanks
http://s157.photobucket.com/albums/t42/Booostedz/
here is my photo bucket check it out
Are you going to convert to HICAS?
so ill tell you guys about how I made my baby seamless I used about 25 tubes of norton speed grip and glued everything first. I also used it on the back bumper as a filler because its super strong and I know it wont crack. so after i did that I did a light filler to level out everything on the back bumper. for the side skirts I pop rivited it and glued it on along with glass putty followed by light filler then polyester filler for the pin holes. Then I used and hs fill surface primer. I only used top notch products on my car. I sanded for days in and out till it was perfect to my specs. ill be back to talk about ti more in 2 hours guys hope you like my ride!!!
can every one view those pictures with out being a user? b 300zx you check the pictures out? you like what I have done?? IM working right now on a custome master cylinder for my brakes and clutch. i also order a cos watever nickle plating kit. im plating all metal lines under the hood its going to be sleek
much much better. much better on the post and spelling also. better setup.
but the hard part on your build is still to come. putting the engine back into the car and makin it run good. lol. but for what you have done so far you shouldnt have to much troubles.
i need some help tho im polishing my 2 master cyinders (clutch and brakes) but does the res come off the brake master? it looks like i could get it off. I dont want to try unless i get some opiouns on taking it off here are some pictures any ways. damm it man i cant find my mandrel for my toosie rolls! ahh i can't get those tight spots till i find it.
much easier to read post. thank you. can everyone get along now?
Ok guys I got a question I got new chrome water pipes with new sensors. ok so I have aftermarket gauge. Really dont want to drill a nother hole. so my idea was to put a resistor inline with the wire for my temp gauge in the dash, so when I start the car it will go up to temp right away then when my car is off it will go back down, then use the hole for my new gauge. what do yah guys think? i found the proper resitor to bring the gauge on my dash up at the right spot so it does not look like im over heating
rethink the wing maybe. just doesnt really flow right IMO.
i dont care for tall wings at all. i guess it is mostly the little "winglets" on the ends that turn me off.
polish the doolz intake also unless you planned on it already, also your gonna paint the car with the engine out yes? if you werent id rethink that. looks cleaner with a shiny matching engine bay. and use the word "ride" less lol. sorry it is just akward to me.
Originally Posted by b300z
im not completely understanding this. are you wanting to install the aftermarket sensor in the stock sensor spot and then run a resistor to the dash to make the needle move still?
i see where he is comin from it would annoy me to as long as he is running another guage obviously. but idk if it seems worth the work or money... even though its not much money lol.
