Light Prblem
Old Mar 11, 2003 | 08:01 PM
GodZilla's Avatar
Banned
Sounds like a fuse or a relay to me..
I'll take a look at my 300 tonight to see if there is anything I can find out..
Old Mar 11, 2003 | 08:35 PM
drag_300japan's Avatar
have you done any work on it lately? or were you driving it and one day they just stoped working?
Old Mar 11, 2003 | 11:36 PM
When you got the front painted did they take any lights off the car ie: fog lights, turn signals ect... I would check all the plugs to all your lights mmake sure there all pluged in. If so then I wound do continuity checks @ the farthest ends of the circits. Its possible that your alarm is wired in such that it gives the the light power via a relay to the positive of the lights allowing them to flash on and off.
Old Mar 12, 2003 | 08:16 AM
ok two fuse boxes one under the hood drivers side just behind the headlight mounted on the fender. the other is behind the kick panel @ your feet next to the pedels on the door side. happy hunting and take a flashlight!!
Old Mar 12, 2003 | 08:56 AM
are you talking about the 1" blocks these are relays the other things 1/2" things are fuses they have clear tops you should be able to see the brass strip unside.
try this manual look in the el section
300zx-twinturbo.com/cgi-bin/manual.cgi
Old Mar 12, 2003 | 05:52 PM
It could be your headlight switch pod try to find sombody that has one to use to trouble shoot with.
Old Mar 12, 2003 | 11:25 PM
U know the thing that u use to turn the lights on and off!
Old Mar 20, 2003 | 04:19 AM
no problemo!!
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
Turbo86
Jan 15, 2007 03:45 PM
zbest91tt
Oct 26, 2002 03:36 AM
Wolfe
Nov 20, 2001 11:58 AM
