Intake Question
Old Oct 12, 2004 | 08:44 AM
QbanZ's Avatar
Intake Question
Quick question for all the Z guru's here... I have picked up a polished Intake off of a 95 tt. Can i use it on my 90 tt ?? are there differences of the vg30dett between those years ????
thanks in advance for the responses ...
Old Oct 12, 2004 | 08:53 AM
91zxtt's Avatar
The intake is the same in those years. It'll fit.
Old Oct 12, 2004 | 09:04 AM
QbanZ's Avatar
Thanks a mil....
Old Oct 12, 2004 | 09:20 AM
91zxtt's Avatar
I was thinking morer about this....do mean the intake pipes, or the plenum?
Old Oct 12, 2004 | 11:22 AM
QbanZ's Avatar
the plenum
Old Oct 12, 2004 | 11:37 AM
91zxtt's Avatar
I'm not 100% sure on that. I've been on a couple different sites that sell the extrude honed upper intake manifolds. The ones that fit models built in 7/89-9/93 are different then the ones that fit 10/93+. This is probably because they're designed to fit with the honed lower plenums; which are different starting in 10/93. The fuel rails are different, so the mounts in the lower plenum have been changed to fit the fuel rails. The stock polished upper plenums fit all TT's. So, is it stock, or has it been honed?
Old Oct 12, 2004 | 11:46 AM
QbanZ's Avatar
I am 100 % sure that it is stock ....
Old Oct 12, 2004 | 11:48 AM
91zxtt's Avatar
Then you should be fine.
Old Oct 12, 2004 | 11:50 AM
QbanZ's Avatar
I hope so !! will let you know if it doesnt... thanks again
domsgarage
Oct 11, 2010 07:44 PM
skittle
Dec 15, 2006 05:28 AM
1SIKZ
Jun 19, 2004 07:34 AM
na300Z
21
Mar 9, 2004 05:53 AM
slig
May 4, 2003 09:06 PM
